4 Ways to Disable-Deactivate the Anti-theft on GM cars ...
? 5:33
www.youtube.com/watch?v=rrRbPdPlecg
Jul 13, 2013 - Uploaded by Misael Fernandez
2. turn the ignition to the ON position and let it stay for 10 to 15 minutes ... How to Disable the Passlock on a 2000 Chevy Malibu or GM cars. .... the same on the Oldsmobile Intrigue?.. will that my bypass switch work on my car?
SOURCE: 2000 windstar anti theft system
un hook battery and wait about an hour or so and use factory key if wont fix dealer has to reset.
SOURCE: Can anyone tell me where the fusebox is for the 2000 Oldsmobile Intrigue.
fastboyz is correct. There are two fuse panels. One in the engine area near the battery as he describes. The other one is on the passenger side at the end of the dash board. You have to open the passenger door. If you look at the dash board you will see a panel box cover built-in to the dash. The cover fits the contour shape of the dash. Pull on the cover and that will expose the fuses.
SOURCE: how do you reset the theft system on a 2000 olds intrigue
Put the key in ignition, turn to the on position and leave it on for ten minutes. Should reset
SOURCE: My Service Vehicle Soon, Trac
Usually it means you have a bad wheel bearing, it has a speed sensor built into it. You will have to have it scanned to pinpoint the problem.
SOURCE: 1997 toyota 4runner anti theft system prevent ignition. How do we deactivate anti theft system.
sorry this is a dealer fix. but it could be as simple as programing a new key.
or it may need a new imoblizer module.
