Question about Sharp Comfort Touch AF-R120EX Air Conditioner
Filter is stuck inside - Sharp Comfort Touch AF-R120EX Air Conditioner
    Champion:
  • 233 Answers
I have had to break the plastic around the filter to get it out before, <not telling you to do that> , but you may have to force it...be careful so you dont brak the faceplate>>>good luck
Posted on Jul 12, 2009
What is the meaning of D02 in Samsung watching machine
D02 Error may have following Causes:
1-drain hose kinked or plugged
2- drain pump failure
3- accumulation of debris in filters and causing the floater positioner got stuck
if there is the flow of water through the drain hose it may that the floater inside the bath got stuck, if this is the case, remove the filters, unfasten the bolts and remove the inside cap until you can see the floater.
clean debris from inside surface of the washing machine and also clean the floater.
Posted on Aug 21, 2015
Dec 19, 2015 | Samsung Washing Machines
I can not get the filter holder to twist off.. It seems to be stuck
Hello friend, thank you for your post!
I understand that your water filter holder is stuck and will not come off of your Frigidaire refrigerator. I see you have the Pure Source filter and after reviewing that it does not appear to have a filter holder. To remove that filter you should have to push it in and it should discharge. If it is not doing so, I would push it in and turn it slightly to remove it. If you are still having trouble with your filter removal could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the inside of your refrigerator normally on the right hand wall. I look forward to assisting you. -Matt
Aug 23, 2014 | Frigidaire Refrigerators
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Error code d02 on samsung dishwasher dmb28afw
d02 Error may have following Causes:
Dec 21, 2012 | Samsung DMB28AFW Dishwasher
Frigidaire side bye side la32700897
YOUR DAMPER INSIDE THE FRIG SIDE IS GETTING STUCK OPEN AND FREEZING THE WATER FILTER AND WILL FREEZE YOU PRODUCE TO YOU WILL NEED TO REPLACE YOUR DAMPER DOOR ASSY INSIDE THE FRIGTOP LEFT CORNER IS WERE IT IS AT
Nov 02, 2012 | Frigidaire Refrigerators
Craftsman.com
look inside the fuel tank you will see a filter hanging on the end of the fuel pick up hose make sure its not stuck it should float around inside a drop to the lowest point of the tank at what ever angle its at i have seen when they get older the line is brittle and the filter falls off
Jun 09, 2012 | Garden
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
115 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
