Question about GE GSH25JFR Side by Side Refrigerator
GE side by side water dispenser
Ice works fine and after looking the other posts think the line is probably frozen- new filter and it has water in it but no water at the door- just can't figure out how to find it and un freeze it???
  • Eggsuckindog Nov 16, 2007
    Thats the big problem I can't find the line, if its in the bottom that is a big help, and I will try that. It worked forever then when they had the filter off and put a new one on it didn't so it probably froze with no water running through it.
  • Anonymous Mar 17, 2014
    How do I un freeze the water tube and or resevior? Is it in the door?
  • 18 Answers
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
Listen to every tip on here!!!!!! For weeks my water dispenser wouldn't work. Of course I am very cheap!!!! So I didn't want to call a repair man. Thankfully these solutions worked like a charm!!!!!
Thanks sssssooooo much!!!!
Trish
Posted on Nov 24, 2007
  • 447 Answers
Honestly the easiest way is to remove the door on a warm afternoon and put it in the sunlight for 2 hours or so there is no way to axcess it. Make sure that the line is frozen first by disconnecting the tube under the freezer door, close door, call for water it should come out in full force there. Have a shallow pan to catch the water. feel free to respond. thanks
Posted on Nov 16, 2007
  • joey  shearer
    joey shearer Nov 16, 2007
    yes the tube is behind the bottom grill. remove the grill and the tube goes up through the bottom freezer door hinge
  • joey  shearer
    joey shearer Dec 02, 2007
    To anyone else having this issue with a Post-2001 GE refrig___
    There is a heater kit available to reslove this
    Anyone is welcome to email me @amasuperbike@comcast.net
    and i can send you the service bulletin describibg the installation
I have a problem with my water tap on the refrigerator. The ice maker and dispenser for ice works just fine. As you know, the ice dispenser and water dispenser uses the same switch. But the water dispenser...
open the refrigerator door and remove the filter. take a flashlight and look inside the filter housing. now take a long screwdriver and push it into the contact point where the filter makes contact. one of these contacts are probably broken, try either side and while pushing it in, press the dispenser for water. water should spray out from the point where you have inserted the screw driver. don't remember the exact name for the part, but i'm pretty sure thats where your problem is.
Feb 06, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice maker tray not filling with water.
Changed the filter, now it works fine. I'd still like to find a way to bypass the filter. My fridge is only 2 yrs. old, but I'm sure it will have plenty of life left after these filters become unavailable.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
G E Monogram side by side refregerator ZISB420DMC
I'm just a home owner, not an expert. Could be a frozen line. I think GE has had problems with this. I think they've retro-fitted their doors with better insulation that prevents the lines from freezing.
Jun 23, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Water dispenser problem?
grandfunk, by your post, it sounds like the line is frozen over. You will have to do some tests. First rule out the dispenser itself. While someone is calling for water see if you have 120V to the water valve. If you do, we ruled out the dispenser. Behind the toe panel there should be a water line with a john guest fitting going up the door. Disconnect it there and call for water. Catch it with a cup. If the water is flowing there, you might be frozen up in the door. I have found a couple of these models with that problem. If it's not flowing there, behind the lower drawers in the refrigerator section is the water coil tubing. Take a hair dryer and go over it lightly. It could be frozen over there. Check these things first and post back. Catriver.
Mar 19, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
95 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
