Question about Nakamichi AV-10 Receiver
Nakamichi AV-10 The tone control seems to be causing the speakers to fade in and out, even when depressed or not depressed. Pressing the button causes static thru the speakers. Any suggestions?
  • Anonymous Feb 18, 2008
    I have always had severe noise when using the same switch, once it is pressed, I hear serious friction in the speakers. This has been very f4rustrating.+
  • jasloff May 07, 2008
    I had the same problem for an year, now the receiver it's not working and the front card needs to be replaced. I don't know if it had anything to do with it, but I'm not happy with my Nak ( I had problems with my Nakamichi DVD player too).
    regards. Javier
  • 1,689 Answers
The contacts in the switch are probably oxidized or warn out. More than likely it is oxidized.
You can get some switch and control cleaner from most any electronics poarts supplier.
You have to open the reciever to get access to the noisy switch. You would then spray a little of this cleaner in to the switch. Then work the switch back and forth rapidly to clean it.
If this does not work, then the switch would have to be changed.
If you don't feel confortable to do this procedure, you can bring the receiver to a service shop. They would be doing this type of service routinely.
Jerry G.
Posted on Apr 23, 2008
My Yamaha rx v 563 brand new used few hours only, doesn't turn on.all speaker's connected,.please give me yr valuable advices Thanks
Try holding the INFO and TONE CONTROL buttons and pressing power. This will release the protect lock. If it shuts back off, try disconnecting your speakers and try it again. You might have a shorted speaker or cable hooked up causing it to shut down.
Feb 21, 2017 | Yamaha Audio Players & Recorders
No audio from Nakamichi av-10 receiver. Checked all connections and speaker buttons. Even headphones don't provide any audio
There is a protection circuit in that unit. It has a relay that is either dirty or has detected a fault that might or might not be there.
Sep 16, 2013 | Nakamichi AV-10 Receiver
Remote controller for Nakamichi AV 10 amp. stopped working last night despite replacing new batteries. Red LED not illuminating when 'power' button depressed. Any suggestions for repair/replacent of...
I got the Nakamichi Av-10 i too face the same problem i just tap the remote with my palm and it starts working...:) just try this am sure it should work
Jan 07, 2011 | Nakamichi AV-10 Receiver
The receiver is muted when playing in tuner or cd the volume is not coming through the speakers. We can hear it muted when turning up to max its very low. Lost instruction manual can you help. I think my...
I can't find a manual either. Can I assume you really mean the sound is muted for EVERY source, not just tuner and CD?
I'd guess it's either MUTED or a Tape Monitor is active. Turn the volume down, select FM as the source, tune a station and use it as your test source. Look around for indicators that give a clue.
NEVER troubleshoot anything with the volume control turned way up. You'll blow up or damage the speakers and your hearing right after you discover and correct the misplaced control.
Aug 15, 2010 | Nakamichi AV-2 Receiver
Hi, my Nakamichi Av 10 receiver tuner and the video AUX section is dead and does not work except for the Tape in
I am facing the same issue All Analog inputs except for Tape in does not work and the tuner does not work on my Nak AV-10
Jun 03, 2010 | Nakamichi AV-10 Receiver
After the recent purchase and professional installation of a used Nakamichi CD 700, I noticed my front speakers weren't working. Activating the fader adjust I noticed that when I turned the knob...
I would recommend taking it back to the pro that installed it given it hasn't been to long. Also the deck should be warrantied and if the front side is not working I would consider that a faulty head unit. I know Nakamichi head units are not cheap.
Go back to the store you purchases it from or contact Nakamichi directly at the link below:
Sep 05, 2009 | Nakamichi Audio Players & Recorders
Nakamichi AV10. Re: left channel softer than the right one.
Its an issue with the tone switch activate and reactivate it to get back to normal volume on both speakers, and would suggest you to clean the switch with WD40 and it should resolve the issue
Jul 16, 2009 | Nakamichi AV-10 Receiver
Service manual
These are not generally available outside of authorized service centers. What is your specific problem with the unit? Perhaps we can guide you on the repair.
Jan 22, 2009 | Nakamichi AV-10 Receiver
Nakamichi AV-7 5.1
in this case the centre speakers are the main route to the sound. 5.1 is for movies, where the centre speaer takes predcedence.
Aug 29, 2008 | Nakamichi AV-7 Receiver
Nakamichi AV-10 very little sound on the center speaker
could be the speaker, try connecting another speaker and cable and see if it improves. If the problem is still there and you've checked all the settings insuring that its not turned down, then could be an internal problem with the receiver.
Hope this helps a little at least.
Mar 30, 2008 | Nakamichi AV-10 Receiver
Nakamichi AV-10 Receiver Logo
261 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
