Question about RCA R52WH73 Projection Television
RCA 52 Model # R52WH73
Replaced the FL231 fuse in our RCA 52" TV and it is still blowing
  • 4 Answers
The solder joints are loose on the flyback transformer and that is what is most likely causing the fuse to keep blowing. Resolder the connections and replace the fuse and you should be good to go.
Posted on Jul 24, 2009
  • 788 Answers
Sorry to hear about your problems with the RSA 52"
This unit has had its share of technical problems in the past.
1st. I have know way of knowing which fuse you have replaced, as their are several which handle limits for different section of the unit.
If you have replaced the main fuse in the power supply and you have not found why the fuse has blown, you are wasting your time in the attempt of repairs.
Example, you have changed the fuse in the power supply.
The problem may be in the audio circuit, which is in series with this supply.
If the audio circuit has a bad cap and it draws a over-limit current, or if the problem is in the vertical high voltage circuit, changing the Fuse will not repair the problem, in-fact will more than likely make it harder to diagnose later down the line.
Hope this information has been of some help.
Thanks,
John Ray
john@johnrraycomputer.com
Readers, please rate your technicians information.
Posted on Jul 13, 2009
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Can't figure out to find auto convergence on remote or tv
Go to menu then setup look for convergence if you do not see it listed you have a open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a Roll small brown rectrangler looking caps but they are fuses it will be the one in the Middle.
Aug 22, 2009 | RCA R52WH73 Projection Television
I have a rca 52 wh74 tv and it showing double images with red, green and blue lines at the top of the screen. how can this be repaired?
Replace the FL231, DL231 and CL230 total cost about 12.00 at the following link which includes the parts with free instructions with pictures. They are listed under the RCA Parts category.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA R52WH73 Projection Television
RCA R52WH73 convergence problem
have you checked the article i wrote on the fl231 problem. its in the tipss and tricks section. ititle the fl231 fuse problem. the convegence option missing is a clear indication of this problem. it a repair that anybody that can use a soldering iron can do
Apr 10, 2009 | RCA R52WH73 Projection Television
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
No Convergence
yes that model is the same itc222 chasis... the fl231 problem is common on all itc222's even more so on that model .. consult the tips and tricks section for the fl231 problem repair instructions
Jan 11, 2009 | RCA R52WH73 Projection Television
Autoconvergence option is GONE!
You will need to replace the ITC222 convergence power supply board and the FL231 fuse on the deflection board. You can get replacement parts at the following link with free installation instructions.
Sep 24, 2008 | RCA R52WH73 Projection Television
Auto convergence disappeared from the menu on my 52" RCA TV, Model #R52WH73. This TV is just 1 week out of warranty and the timing is impeccable.
Replace FL231 that will bring back your convergence option in the menu. If the Fuse blows again, you will need the Convergence power supply board. If you need more assistance please let me know
Aug 06, 2008 | Televison & Video
RCA R52WH73 Projection Television Logo
340 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
