Computer will not boot up. Box in center reads: No input signal.
    Scholar:
  • 113 Answers
You are not getting a signal which would suggest you check your power supply first .....next would be hard drive ...
Posted on Jul 13, 2009
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
It saying .. No Sync what does that mean?
No Sync indicates that the input signal doesn't match the type of signal that the TV can read. A digital source going to an analog input could cause the issue.
What is your source for the signal?
If you are using the DVI connection on the TV to connect to a computer, try using the VGA input instead. Unfortunately not all TVs can interpret the computer's digital signal. (It is different than the digital signal from a set top box.)
The manual for the TV is available from the product site: http://insigniaproducts.com/products/televisions/IS-LCDTV32.html . The direct link to the manual is: http://insigniaproducts.com/cms/documents/IS-LCDTV32%20UM%20EN_SP_FR.pdf .
Please add a comment with your source and I will offer additional suggestions for solving the error.
I hope this helps.
Aug 02, 2011 | Insignia IS-LCDTV32 32 in. Television
When turning on my monitor the Acer name appears then disappears and a box that reads "no signal" appears. Then the screen goes blank and the blue power button turns yellow.
This means that your monitor is not receiving a signal from your computer. The easiest way to fix this is to plug the monitor into the computer. I hope this helps and have a nice day!
May 03, 2011 | Acer Computers & Internet
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
My acer switchs on but the moniter has stopped working it clicks back to standby and says no input signal
That is because no signal is sent from your computer to the monitor, I suspect your computer is not booting up. Does you computer sound a beep on boot-up? or no sound at all? Have you system unit checked on the nearest support center, or you can troubleshoot it if you want, just send here the details of your troubleshooting and we will be happy to guide you with that.
Nov 22, 2009 | Acer Aspire M1641-U1521A PC Desktop
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
TV stuck in Monochrome on the S-video input selection
S-video input is stuck in monochrome- when the small center box appears allowing you to change the input, the S-video box reads monochrome at the bottom. I cannot find a way to change this and have misplaced my user's manual. Help!
Thanks-
jg
Apr 09, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
