Question about D-Link DI 514 Wireless Router (DI-514)
NetGear wireless router model wpn 824 v2
I can connect to the Internet directly from the cable modem, but not wirelessly when the modem is connected to the wireless router. What do I need to do?
  • Anonymous Mar 26, 2014
    How do you disconnect the NETGEAR CMD31T cable from the internet?
  • 173 Answers
  1. Then u have to setup ur router first
  2. Turn off the power on your computer.
  3. Securely connect an end of an Ethernet cable to your computer, as shown.
  4. Securely connect the other end to any of the router's four LAN ports.
  5. Connect a second Ethernet cable from the router's single WAN port to the modem.
  6. Make sure the modem is connected to the jack or cable to the Internet that was set up by your ISP.
    1. Start your network in this order:
      1. Turn the modem power off.
      2. Turn the router power off.
      3. Turn the modem power back on. Wait two minutes until the lights are stable.
      4. Turn the router power back on. Wait one minute until the lights are stable.
      5. Turn the computer power back on.
    2. Open an Internet browser, and type If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to
    3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
    4. Click OK. This logs you into the router.
    5. Click Setup Wizard, on the left of the router settings page and set up your router
    6. that would fix your problem..
Posted on Nov 16, 2007
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
I'm trying to connect a netgear wpn 824 to a comcast router with windows 7
You are trying to set up the wireless router with the comcast modem, right ?
You can set up the router manually , without the disc.
Make sure that your computer is able to go online when connected to the comcast modem only.
If you have the router working already then you just need to add a computer to the network.
Click Here for step by step solution
Oct 27, 2009 | NetGear RangeMax WPN824 Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
I cannot find my wpa or wpn on my wireless netgear 824 v2
You shouldnt be able to find the WPA or WPN you would have set this when you first installed and setup your wireless netgear router. Your supposed to write it down before the installation completes I had one. There should be a saved file that Netgear saved during installation that states your password and other info.
Apr 03, 2009 | D-Link DI 514 Wireless Router (DI-514)
Ipod touch not connecting to router
wireless router wpn = password check under your router for a passcode or somewhere on it or call your nearest internet place
Jan 08, 2009 | Apple iPod touch
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
Trying to hookup a wireless router to HP 1100
DSL uses PPOE, which may be different than what you had previously. Cable, for example, uses TCP/IP.
Re-set the router to defaults, and follow the instructions for PPOE, which should be in your manual or setup disk. Your ISP may have this info on their site, or you can get it at the Netgear site:
Oct 17, 2007 | 2wire HomePortal 1100 Router...
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
D-Link DI 514 Wireless Router (DI-514) Logo
498 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
