Question about JVC Audio Players & Recorders
Speed not right - JVC Audio Players & Recorders
  • 1 more comment
  • pjh809 Jul 22, 2009
    direct drive.the speed is too fast at times and sometimes to slow.not way off but you can hear it not something you want to listen to.
  • Tony A May 11, 2010
    Is the speed on 45 or 33 ok?
    I would like more information on the please. Is the deck belt or direct drive?
  • 69 Answers
Explane?
Posted on Aug 07, 2009
DTC code C1226
Definition of Diagnostic Trouble Code C1226 Buick: Right Front Excessive Wheel Speed Variation Cadillac: Right Front Excessive Wheel Speed Variation Chevrolet: Right Front Excessive Wheel Speed Variation Chrysler: Brake Pedal Travel Sensor Circuit Dodge: Brake Pedal Travel Sensor Circuit Ford: Brake warning indicator output short circuit to ground. GMC: Right Front Excessive Wheel Speed Variation Jeep: Brake Pedal Travel Sensor Circuit Lincoln: Brake warning indicator output short circuit to ground. Mazda: Brake warning indicator output short circuit to ground. Mercury: Brake warning indicator output short circuit to ground. Mitsubishi: FR inlet valve Oldsmobile: Right Front Excessive Wheel Speed Variation Pontiac: Right Front Excessive Wheel Speed Variation Saturn: Right Front Excessive Wheel Speed Variation Toyota: Open or short in hydraulic brake booster solenoid circuit (SA2/SPC/SPFR/SPFL/SMV1/SMV2/SBAL)
Locksmith East Aurora Ny 24 Hour Locksmith 716 249 2944 in East Aurora Ny
Jul 31, 2016 | Cars & Trucks
What are the probable causes of DTCs C0222, C0226, and C0237?
Brent, Check and clean connections(use electronic contact cleaner), make sure wires are not damaged. Check grounds from EBCM controller. Check links below and don't be afraid to google search for more info.
C 0222 Missing Right Front Speed Signal
C 0226 Missing Left Front Speed Signal
- Faulty Right/Left Front Speed Sensor
- Right/ Left Front Speed Sensor harness is open or shorted
- Right/ Left Front Speed Sensor circuit poor electrical connection
- Faulty EBCM
C 0237 Erratic rear speed signal
- Faulty Rear Speed Sensor
- Rear Speed Sensor harness is open or shorted
- Rear Speed Sensor circuit poor electrical connection
- Faulty EBCM
How fixed Chevy with an Abs and Brake light on
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwi0i8zz5YzLAhWD74MKHffwDLQQtwIIITAC&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DR_5WZUebDx8&usg=AFQjCNHimqe_Fje8AySjD5N0Wh8z8dQuuw
How To Install Replace Front ABS Sensor and Harness 2000 06 Chevy Suburban...
Feb 23, 2016 | 2003 Chevrolet Tahoe
Where is the vehicle speed sensor located in a 1999 Buick century
Vehicle Speed Sensor Replacement
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information. Remove the right front tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels. Remove the right engine splash shield. Refer to Engine Splash Shield Replacement in Body Front End.
Remove the vehicle speed sensor wiring harness connector.
Remove the vehicle speed sensor bolt (9). Remove the vehicle speed sensor (10) from the extension case.
Remove the O-ring (11) from the vehicle speed sensor (10).
Vehicle Speed Sensor (VSS)
Lower right side of the engine compartment, on the transaxle
Sep 05, 2015 | Buick Cars & Trucks
Como puedo cambiar los sensores de la transmission de un 2002 trailblazer ls4x4
Vehicle Speed Sensor (VSS) Inside automatic transmission assembly.
Wheel Speed Sensor-LF On left front wheel hub assembly.
Wheel Speed Sensor-RF On right front wheel hub assembly.
Wheel Speed Sensor (WSS) - LR Attached to left rear wheel hub.
Wheel Speed Sensor (WSS) - RR Attached right rear wheel hub
Jul 08, 2014 | 2006 Volkswagen Jetta
How to get 100000 in need for speed carbon
Cheat List:
Enter the following codes at the Main Menu for the desired effect: 1. Extra Money: Down, Up, Left, Down, Right, Up, X, B to get an extra $10,000 in Career mode. If you entered the code correctly, a message will appear.
2. Infinite nitrous: Left, Up, Left, Down, Left, Down, Right, X. If you entered the code correctly, a message will appear.
3. Infinite crew charge: Down, Up, Up, Right, Left, Left, Right, X. If you entered the code correctly, a message will appear.
4. Infinite SpeedBreaker: Down, Right, Right, Left, Right, Up, Down, X. If you entered the code correctly, a message will appear.
5. Need For Speed Carbon Logo Vinyls: Right, Up, Down, Up, Down, Left, Right, X to unlock the Need For Speed Carbon Logo Vinyls. If you entered the code correctly, a message will appear.
6. Need For Speed Carbon Special Logo Vinyls: Up, Up, Down, Down, Down, Down, Up, X to unlock the Need For Speed Carbon Special Logo Vinyls. If you entered the code correctly, a message will appear.
Sep 02, 2012 | Microsoft Xbox 360 Elite Console
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
How do you set the cruise control on my 2008 Road King Classic, FLHRCI. I bought the bike, no manual... Thank-you
Luckily, I have a 2008 Road King Classic (FLHRC) WITH a manual!
On the left handlebar switch housing there is a lever below the left turn signal button.
It should be flipped to the right for the cruise control to be on, left is off.
On the right switch housing, is a similar lever, below the right turn signal button.
When you're above the minimum speed (I do not know what this is, but 30 MPH is not fast enough for it to engage), push the lever to the right (towards the grip end). This will "SET" the speed.
If you hit the brakes, or accelerate above a certain rate, the cruise will kick off.
To get back to the set speed, when you're above the minimum speed, flip lever to the left to resume.
When the speed is set and engaged, to increase the set speed, flip right lever to the right, to slow, flip to the left.
Apr 13, 2009 | 2008 Harley Davidson FLHX Street Glide
How do you speed up the printing speed on a Paxar 9800/9850?
Press "escape"
Press Right arrow til display says "setup"
press "enter"
Display now says "supply"
press "enter"
right arrow til you see "speed"
press enter
adjust print speed IPS is "inches per second"
press enter after you change speed. hit escape key 3-4 times, then enter - you should see "print mode ready
If speed doesnt change it could be because the print speed is set by the software OR by the type of barcode you are printing. Serial barcodes default to 2.5 ips.
Apr 08, 2009 | Paxar Monarch 9825 Thermal Label Printer
49 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
