Question about New Balance Exercise & Fitness
Our New Balance 1400 treadmill starts to slow down at about 10 minutes into the run/walk. When I step off the machine, the treadmill speed moves at the high rate of speed. When we called Fitness Quest for help, they said it was the motor & sent us a new (rebuilt) one. Still does not work. We have recalibrated the treadmill as per their instructions and still no solution. Could it be the console?
  • 4 Answers
Please check wheel setting ( When calipration)
sada
Posted on Jul 13, 2009
I have a New Balance 1400. How do you do a hard reset on it?
In almost all treadmill error 1 denotes the speed sensor error.
In you case I suspect there is some variation in the alignment of the speed sensor. May it moved away from the magnet Which is fixed on the rotating wheel. Try to make it closer as much as it can, be sure not to keep a small distance .hope it will solve the problem.
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | New Balance 1400 Treadmill
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
My walking machine is running really slow and the mat is going side to side when we are running
my walking slows down when walking close to top and speeds up closer to the bottom of the treadmill.
Feb 11, 2013 | Sportcraft Exercise & Fitness
Speeds up and slows down
Dear Sir:
Please adjust the sensor speed for the main motor. Of course I am recommending Very Strong to RUN the software calibration for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnosee
Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Nordic Track NordicTrack A2550 PRO...
I have a Nordic Track EXP1000 that wad purchased
Go to iconservice.com click on manual input manufacturer and model name 1000.
Try this calibration procedure:
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
5) If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
6) The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
7) It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
8) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
9) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.Press the Stop key once and remove the safety key.
If you still do not have belt movement then call iconfitness @ 1-800 999-3756
Jun 26, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a 1400 that when it has been running for 20 or 30 minutes goes to Power Failure and generally throw me against the rail to an abrupt stop. I do believe it is home electrical as I run a 20 amp...
This generally means that lubrication is needed to be applied between the belt and belt. You may purchase these kits thru www.jadfitness.com the products name is Lube and Walk follow the instructions that come with it to apply the lubrication.
Jun 11, 2010 | New Balance 1400 Treadmill
Will not move belt
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
146 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
