Question about ViewSonic VA902B 19" LCD Monitor
I have a viewsonic VX2235wm and the screen has just recently started "shaking"? After it warms up the shaking/flickering goes away, sometimes! Is it dying?
  • 11,361 Answers
Viewsonic vx2235vm does not turn on
This really sounds like you have a power supply board that is having problems with the filter capacitors which are causing it to not start up correctly. Here is a like to a repair guide including video instructions showing how to open and repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Part one of the video guide:
Feb 07, 2013 | ViewSonic VX2235wm LCD Monitor
Just started flicker today, I've had this monitor for at least 2yrs and no issues ever. VX2235wm and used ALL the time.
The problem is in the power supply / inverter board, commonly caused by bulging capacitors at the top, "indicating they are open" the capacitors will need to be replaced to correct the issue.
Mar 25, 2011 | ViewSonic VX2235wm LCD Monitor
LCD model viewSonic vx2235wm 6 months out of warranty, When powered up, the backlight will flash, but then screen is dark. The blue light at the bottom is on and Vista recognizes the monitor. Sometimes, I...
Are you sure about no bad caps? The top of the caps have to be completely flat, and bad caps can also look normal but can have high ESR, you will need meter that can read ESR of the caps.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Post the pictures of the board and caps.
Sep 05, 2010 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235WM turns on than screen goes blank changed power cords cable cords viedo card cpu still same problem
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
Nov 28, 2009 | ViewSonic VX2235WM Monitor
My viewsonic vx2235 has a blue light on but no picture at all. Can i still use this monitor? I really dont want to buy another one so i am hope that i can just replace a part cheaply. Theres power but no...
Assuming your cable is good & your PC (video card) is properly functioning & everything is plugged in correctly,;
If the screen flickers a bit when you start it, then the problem may be in the power circuits. Open the back & look for burned components on the circuit board. (capacitors, fuses, resistors, transistors, whatever.)
If it does not flicker then the bulb is likely burned out.
ALSO: you should read this guy's experience. ----> http://www.avsforum.com/avs-vb/showthread.php?t=1136249
Sep 05, 2009 | ViewSonic VX2235wm LCD Monitor
Moniter flips out after it warms up
I repaired my VX2235WM that wouldn't turn the display on anymore (would accept a video signal for a PC, but no image would be shown) by replacing 5 stressed electrolytic capacitors on the power supply board.
Apr 04, 2009 | ViewSonic VX2235WM Monitor
Vx2235wm lcd flickers a bit then turns white
White screen is an indication of a faulty video board.
A blown fuse in the actual screen will cause the same effect but usually these do not reset on a fresh startup.
You can check the ribbon going from the video board to the back of the screen to see if it is somehow working loose, but I think based on your description that this isn't the problem.
ebaysbammbammfran
Oct 07, 2008 | ViewSonic VX2235wm LCD Monitor
ViewSonic VA902B 19" LCD Monitor Logo
141 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
