Question about Yamaha DVX-S120P System
Region Error: Disc and player do not match
Or something like that.
After getting the error, I checked my setup and discovered that the player now thinks it's in Albania!!!
No matter what I've tried I can't reset to the original Region 1.
  • 4 Answers
You are usually limited to changing the region code 5 times per dvd player. This limitation is set in accordance with the requirements specified by major film studios. It sounds to me like someone was in the setup menu playing with the region codes, and did it a couple of times. Possibly one of your kids. So basically with this limitation once it is switched the 5th time it cannot be switched again. Sorry for the bad news.
Joe
Posted on Jul 13, 2009
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
I put in my dvd on my magnavox blue ray player and it says disc error then something like disc not recorded for thins region code * 2 * 45 *
DVDs are recorded for three world regions (for copyright reasons and to match the electronic TV system also broadly in three world regions known as PAL, SECAM & NTSC)
You're likely in the USA as you refer to the Magnavox brand.
Your region is 1 and system NTSC.
Your machine is correctly telling you it can't play the disc because it's for Region 2 system PAL.
However, there are multi region players available, for a few dollars more, which play discs of any region or system.
Sep 20, 2011 | Audio Players & Recorders
How to solve disc region error?
Here's how to make it region free..
1.Keep Tray in eject position
2.Press Setup from remot
3.Go to preference page
4.Press"138931"
5.Using Navigation Key change region code to "0"
6.Press "OK"
7.Regionfree!!
Jay
May 25, 2009 | Televison & Video
Region Code Error for Philips DVP3256
hi
you can try this
>Go to Setup.
>Select Preference Page.
>Press 1, 3, 8, 9, 3, 1 on the Philips DVP3986 DVD Player remote.
>Press the up/down key to select "0" which makes it region free.
>Press ok and exit setup.
riz.
Feb 24, 2009 | Philips Televison & Video
Region code
Turn the player on and make sure that there is "no disc"
1. Press "SETUP" on your remote
2. Press "3141590" there 0 is region 0 (region free)
Menu disappear and your player is now region free.
This should work.
Jul 20, 2008 | Harman Kardon DVD Player DVD-27
DVR doesn't read disc, says region doen't match
check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Jan 22, 2007 | Yamaha DVR-S120 DVD Player
Blocked error message
I would imagine it's eitehr a Region problem or a parental level problem. Ensure the region DVD matches the Region of your DVD player. Also check the parental rating level within the DVD player is not active or set to 18.
Jan 26, 2006 | Yamaha DV-S5450 DVD Player
Yamaha DVX-S120P System Logo
119 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
