Question about Maytag Dryers
My old Maytag DE307 dryer gets hot right away, then after about 2 minutes or less, stops blowing hot and goes to warm. Let it cool down,and the cycle repeats.
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This is generally an airflow issue. Restricted airflow will cause the hi-limit thermal protector to open and turn off the heat in order to prevent a lint fire, or fabric melt issue. Remove the exhaust vent from the dryer and ascertain that there are no obstruction/restriction to the vent hood, Include the vent hood in your inspection to make sure it has not been crushed or damaged. Make sure your lint filter is cleaned after each load. Do not use fabric sheets as this will place an invisible coating on the lint filter that restricts airflow, (Replace filter). Do not overload the dryer. If your washer is newer, then larger loads are capable of overloading the dryer.
A blower malfunction or worn belts could cause lower airflow issues. Replace if worn.
Visit; www.repairclinic.com, for complete DIY instructions, disassembly procedures, and repair parts list.
Hope this helps.
Posted on Jul 13, 2009
Maytag MED5700TQ electric dryer heats too hot during cool down cycle and clothes come out wrinkled
Replace the control thermostat and clean out the filter chute is what I would do. Take the whole thing apart and clean it up. To get to the control thermostat remove the dust cover on the back and look for a skinny white fuse on the blower housing. Next to it is the suspect part. It has 4 wires. 2 small ones operate a tiny heater inside that warms the bimetal. It is used for knits and permapress. It makes the bimetal open the circuit faster. It has failed and the stat is no longer shutting down properly.
My home video shows how it goes together and what to check:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 04, 2012 | Maytag MED5700TQ Electric Dryer
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
My gas dryer starts normal but then the flame stops and it cycles trying to relight it
Replace the 2 coils on the burner . After warming up , 1 will " short " internally , opening the circuit . After the dryer cools down , completely , it will work again , until the coil warms up . Only 2 screws hold the bracket holding the coils on , Gas does not have to be turned off to replace these coils . Easily replaceable .
Apr 18, 2010 | Maytag Dryers
MAYTAG DRYER DRIES 2 LOADS THEN WONT START UNTIL IT COOLS DOWN
usually it's the motor,there's an overload on the motor that shuts it down when it's to hot,when was the last time you cleaned out the dryer?there could be lint covering the motor,this will overheat it,clean out the duct that the lint filter slides into,blow out the vent line and vac the inside of the dryer where the motor is,next time send the model number and how old the dryer is,clean out the dryer and don't do one load after another and you can still get some life out of the dryer,if the dryer is old use it until it dies
Mar 08, 2010 | Maytag Dryers
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
Whirlpool dryer takes 2-3 cycles to dry a full load of clothes
I would check for a faulty high limit thermostat. This is a small round device mounted on a metal plate and attached to the internal ductwork. It's recommended that the thermal fuse be replaced at the same time and may come as a set from a parts supplier. I will attach a photo of a fuse/thermostat for reference. Remember to disconnect the dryer from power source before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
Sep 25, 2009 | Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Dryers Logo
119 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
