Question about Tools & Hardware - Others
Can a Vibratr Ruin Your S3x Life? - Tools & Hardware - Others
    New Friend:
No it wont, it will only help :)
See here for more info. VIBRAT
Posted on Sep 27, 2015
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Is most olive oil sold for FOOD mixed with soy oil?
try buying genuine brand oils sealed in bottles. Generic brands may be mixed but genuine brands would not do this as it would ruin their reputation
Nov 17, 2014 | Cars & Trucks
Powerschool login grades
Don't do it, the consequences could ruin your life.
May 14, 2014 | Computers & Internet
Why is my camera stating write protect?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 26, 2012 | Kyocera Finecam S3X Digital Camera
Its a water pump for our house and barn pumps probably close to 300 to 400 gallons a day over the course of the day was wondering if it is wired for 220 if using it with 110 will ruin it
Unless the pump motor has provision on it specifically for running on 110, then yes, running a 220 motor on 110 will ruin it. It will cause the motor to overheat, if you can get it to work at all. Some 220 motors are designed so that you can run them on 110. If yours is, it should have instructions and a wiring diagram for that. Even if it IS designed for 110 or 220, running it on 110 WILL cause it to run hotter, and will shorten its life.
Mar 04, 2011 | Plumbing
What kind of special coolant is needed for a 2002
Its an extended life coolant. Adding regular coolant to the extended life coolant will ruin the extended life characteristics of the extended life coolant. Any good parts store will have coolant compatible with your vehicle.
When your cooling system is ready to be serviced (flushed) most shops will convert it to regular green coolant. Although the green coolant will not last as long as the extended life coolant it is much cheaper even with the more frequent service intervals.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 03, 2010 | Chrysler Voyager Cars & Trucks
I have zenith director model- z8081 purchased 5 years back, i want to replace the battery, a battery life which lasts atleast for 3-4 hrs
This is an expensive buisness,you can get high endurance replacements (copies) or the genuine thing.
Youll have to consult Manufacturer for estimated life.
And use correct/original adapter not to ruin this lifespan of a new/ replacement battery
Sep 07, 2010 | Computers & Internet
When should i charge batteries, should i plug in everyday even if not using my power wheel chair
No.. dont do that.. as that might weaken up your battery and ruin its battery life.. Only charge it when your using it!
May 23, 2010 | Invacare Pronto M51 Power Wheelchair
Casio XJS10 Superslim XGA DLP 2300 Lumens Projector I need a manual for this projector . Do you have one?
I am sorry could not locate SJ-S10 but the SJ-S3X series is similar to SJ-S10 so you might want to get one of them.
http://support.casio.com/manuallist.php?rgn=1&cid=007
You can also use the contact them by e-mail for the manual using this form
Hope this helps,
Sai.
Apr 22, 2010 | Casio Cameras
Lost the driver cd rom for instilled the picture on pc
Kyocera does not list the S3X, but the driver software listed for the S3R will probably work for you. NOTE: according to the site, the driver is only needed for Windows 98 and 98SE. Windows 2000, Me, and XP are plug and play (no software needed). Vista and Windows 7 may or may not be supported. You can download the driver here:
http://www.kyoceraimaging.com/driver.htm
BillB
Jan 31, 2010 | Kyocera Finecam S3X Digital Camera
Tools & Hardware - Others Logo
542 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
