Question about Kenmore Heating & Cooling
Swamp cooler only works on high - Kenmore Heating & Cooling
    Scholar:
  • 91 Answers
I;m assuming that it at one time worked on low speed? If so the wiring from the switch to the unit has come loose, or multi speed motors have multiple windings in the motor itself. The only way to check on either of these neccsessitates visually inspecting, which is usually more safel done by a trained professional. If you decide to look into it yourself, make sure you turn electric off to the circuit before opening anything. If you want to check the motor windings you must know or learn how to perform a continuity test. Good luck. P.S. ou may just want to get by with one speed, replacement motor retails $50-$80.
Posted on Jul 12, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
  • 340 Answers
SOURCE: Breezair swamp cooler parts
applianceparts.com try the manufacture web site johnstonsupply.com should have a pump you can make work. Tom
Posted on Jun 28, 2009
mrjfisher
  • 141 Answers
SOURCE: Got an Adobe Air Swamp Cooler Model # P228101A. Lo...
Indoor Comfort Evap Cooler & AC Parts, Phoenix AZ 85021 2001 W Cheryl Dr, Phoenix, AZ 85021
www.merchantcircle.com › ... › AZPhoenix85021
They say they have parts for your unit.
Posted on May 19, 2010
shastalaker7
  • 1515 Answers
SOURCE: swamp cooler fan works good on low but when you
Hi, its possible it could be the motor. You should have a 3 speed motor. The switch should be Hi, Med, Low, cool, same on vent, and pump. If it works good on cool, I would say the riostat switch is the problem not suppying enough voltage to run the fan motor at full speed. They are very easy to change out, just have the new one in front of you. You can go on the Internet and type this in, directions for wiring this and it will show you the diagram. You may want to go up and check the condition of your belt also. Look for cracks, see how loose it is, it should have about 1/2 inch of play when you push down with finger. If not, tighten it by moving the motor bracket. It may be just the belt also. Look at it all. My bet would be the switch. Keep me posted on what you find.
Sincerely,
Shastalaker7
Posted on Jun 09, 2010
  • 396 Answers
SOURCE: Do not know how to work/maintain swamp cooler
Evaporative coolers are only for dry climate conditions or deserts. They cannot cool as much as central air or air conditioners which have compressors and refrigerant. The mechanics are simple requiring a water float valve, pump, spider (water distribution), aspen wood pads, blower, belt, motor, and switch. The unit must have a water supply to replenish the system due to evaporation. Your system may have a float valve which you need to adjust to shut off when the water pan is full. Floats can be adjusted by loosening the pivot screw and moving the float up and down to adjust the turn off level or by turning the float to extend or retract the length changing the water shutoff position. You do not want the water to be so high it flows out the over flow tube but the water should cover pump base. Plug in the unit and turn the switch to pump if you have that option on your unit. This will engage the pump to force water from the pan up to the spider to saturate the pads with water. After a few minutes turn the switch from pump to low or high cool. New aspen pads will have an distinct smell which will go away after a few days of usage. If you do not have a pump setting turn the switch to low or high cool which will blow warm air at first then start to cool down. You may also have a fan setting which will blow outside air without any additional cooling if the outside air is humid. Occasional maintenance is to make sure the pump is pumping water and the filter basket is clean and all the spiders are working with water flowing freely. You can use a flexible wire to force it in a spider tube to clean it if it is clogged. You may want to change the water after a month to keep the system cleaner from slime and calcium. At the end of the season disconnect the water supply and drain the water pan blowing out the water line if the winter is below freezing. Replace the pads if they have calcium build up or dry. Flush the water pan out and clean the Add some oil to the pillow blocks which are the bearings at each end for the blower. Check the belt and pulley for excessive wear. Cover the unit with canvas to prevent cold air from coming in during the winter. Next summer season all you have to do is uncover the unit and hook up the water supply.
Posted on Jul 27, 2010
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
Swamp cooler is not blowing cool air
is the units Disturbing the water over the pads!
if not check the water pump!
are the pads old and worn out, buy new ones.
and if the Humidity is to high they do not work well
Jul 16, 2009 | Heating & Cooling
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
Swamp cooler is not blowing cold air. Water is
Jun 25, 2009 | Heating & Cooling
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
259 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
