Question about Sharp Aquos Televison & Video
How to fix my sharp aquos LC42D69U lcd tc
Hi. I have a sharp aquos Lc42D69U, TV will turned on, the sound works, but there is no picture. This problem affects all inputs. Sometimes I can watch Tv few minutes before the screen go black. So I will turn it off and back again, the image will be back for few minutes until go black.... and sometimes no display at all,just black. Also the image display will flash. After browsing some sites, I find out it may be the backlight. So I order a new backlight inverter board and installed it but still not working.. could it be the main board or T-con... thanks
  • Sharp Master
  • 2,008 Answers
Use coldspray to find the bad component abad soldering or a few bad capacitors in the (mains) powersupply . knock and bend the electric print some little the beginning is the powersupply
SHARP LC 32D59U LC 42D69U Service Manual free download schematics eeprom...
Posted on Nov 24, 2015
5 Suggested Answers
SOURCE:
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
What are the 4 screw sizes on the back of my LC42D69U tv that are used to mount the tv onto the wall or the tv stand?
They are metric and you can most likely go to a hardware store and see if they will let you borrow a series of them to see which ones fit. The only issue is to make sure they are not too long.
Sep 16, 2015 | Televison & Video
Sharp aquos dolby digital tv has sound but no picture
go to source on your remote then click down to the second one like HD ONE.
Feb 21, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a Sharp Aquos 32" TV. Almost everyday, the
Maybe the cords have the problem.
You might have to pull and reconnect the cords and do the same basic turning on/off of the Tv.
Or you might also check the positioning of your Tv, example : are there stereos or speakers near or beside the Tv? it causes magnetic reaction and causes the screen to not work properly.
Dec 30, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv picture turns off by itself. sound still
the problem of your LCD TV is maybe there is something loosing up when heated on the backlight board of your LCD TV......all you have to do is resolder it or reheat it with a hot air...........if you dont bring it to the sharp service center
Oct 30, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aquos 46d62u has sound, but no picture
We have the same problem with our 32" Aquos. Turn on the TV and after a couple seconds the picture goes out but still have audio. So this solution doesn't permanently fix the problem, but it works instantly to get the picture back. With the TV turned off, tap the side of the set twice with the palm of your hand. Turn the TV back on, and VOILA, you have a picture. I know the last thing you think to do is to hit your TV to fix it, but that is often how my husband tries to fix things...this time it worked!!
Apr 20, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
213 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
