Question about Sony CDX-4000X CD Player
No radio reception
My CDX-4000X radio will not pick up any radio stations, just buzzing staic. I ohmed the antenna wire from where it plugs in to the radio to the antenna (directly on the antenna) and read 0 Ohms. Beyond that I'm stumped.
  • 50 Answers
SOURCE: lost ariel reception hookup
Any car stereo shop should have what you need. Might be a special antenna adapter for certain vehicles.
Posted on Jul 06, 2009
  • 1126 Answers
SOURCE: I need wiring diagram for CDX 4000X
Here is a link to Sony for your CDX-4000X wiring pin outs with color code.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Posted on Dec 07, 2009
  • 1126 Answers
SOURCE: do the cdx-4000x have a ipod plugin
No, not directly. Here is a link to Sony for your CDX-4000X Operating Instructions.
http://www.docs.sony.com/release/CDX4000X.pdf
Belkin as well as many other companies make devices that plug into the ciggarette lighter and then into your iPod. There is an FM tuner controller than sends the music from the iPod to an FM station on your head unit. Belkin calls theirs a 'tunecast auto'. I believe it sells for about $30 USD.
Posted on Dec 26, 2009
caroldon
  • 17130 Answers
SOURCE: Sony CDX FM reception
Yes you need to check your antenna if the tuning has not shifted. there could be an insulation fault if the antenna have a faulty cord within. the present models come with a fixed antennae and so the problem is limited. Look behind the set to see if the jack to the antenna input is loose. You can connect another one to confirm this , if so change with an original replacement as there are many spurious low quality ones. I am sure you will get more years of use. Good day.
Posted on Jul 07, 2010
welcomejee
  • 10594 Answers
SOURCE: I need the wiring diagram
Click Sony Support to download Wiring harness info
Always trust manufacturer support site for correct info about unit
Thanks.
Posted on Aug 18, 2010
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
Do the cdx-4000x have a ipod plugin
Dec 26, 2009 | Sony CDX-4000X CD Player
I have a Sony cdx-c5005 in my Bryany boat that doesn't get any FM reception. CDs work perfectly fine.
Make sure that antenna is plugged in CXD-C5005 to provide radio signal to tuner, without antenna it wont give you any station sound.
Nov 10, 2009 | Sony CDX-C5005 CD Player
Display show 'No TP'
your arial might have come unpluged but you will have to get someone to take a look at it
Sep 02, 2009 | Sony CDX-4000X CD Player
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
My sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Feb 19, 2009 | Sony CDX-4000X CD Player
Mazda MPV Radio Problem
THE GROUNDING ON THE ANTENNA REPLACE THE WIRE AND ANTENNA MAS
Mar 05, 2008 | Sony CDX-L410X CD Player
Radio reception
the wire you use for the antenna is damage replace it or change the set to a other location.
Feb 19, 2007 | Brookstone Micro CD System with MP3 Shelf...
Sony CDX-4000X CD Player Logo
71 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
