Question about Brookstone Slim Profile CD System CD Player
The remote does not work; the battery was replaced.
  • 189 Answers
HI
It's very rare that a remote control would just stop working, take out the new battery and look at the contacts. Are they slightly corroded or tarnished in some way? If so, use a small nail file or emery board to get them shiny. Try it again. If there is still a problem you need to find out if it still transmitting so, use a radio with AM or Medium Wave/Long Wave on it, press any button on the remote and tune through the band and you should hear it pulsing.
If there is no pulsing sound or the item it is for is not responding then you may have to replace the remote. Sometimes those cheap remotes with a book of codes can work the item in most cases. I have a Rotel CD player and have used such a remote to work it.
Hope this helps you and the best of luck.
Posted on Jul 21, 2009
My remote stopprd working! I replaced the batteries and it still does not work! FCC ID. M8CRL. 103
Disconnect power at the source, then remove batteries from remote and press all buttons to eliminate a stuck button problem. Reinstall batteries. Restore power and test operation.
Jul 05, 2016 | Dryers
Why isn't remote working after battery replacement?
As long as the battery produces what the remote needs it should work. However the remote itself could be faulty. Or the remote sensor on your device could be faulty. Check that the old battery has not leaked and messed up the contacts. Plus the new battery is actually touching the contacts!
Feb 25, 2016 | Audio Players & Recorders
REMOTE DOES NOT WORK I HAVE CHANGED BATTERIES
If you have been change the battery but remote still not work, please dissemble your remote check battery lead/wires for defective and other part on pbc. If nothing wrong there, the problem is usually the IR bulb on remote. Try replace with same model or just replace your remote with new one.
Regards
Regards
Mar 26, 2011 | Televison & Video
I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Apr 22, 2010 | Logitech Harmony 550 Remote Control
Remote for Sony vcr works intermittently.
Sounds like the connections inside the remote are damaged and might need soldering. Check the connections around where the battery terminals are carefully. Has a battery leaked in the remote?
Jan 28, 2010 | Sony SLV-N500 VHS VCR
Ford F150 remote key does not work after car battery
cbridges2232,
Any luck with your keyless remote issue? I'm having the exact same problem with my Ford F150 CrewCab after car battery replacement.
Oct 07, 2009 | 2001 Ford F150 Styleside SuperCrew
My remote stopped working. Replaced batteries so
1) Reset the remote. To do this, remove the batteries and hold down one of the number buttons for about 5 seconds to drain the capacitors. Replace the batteries, reprogram the remote to your TV and see if it works.
2) If it doesn't, try a second set of replacement batteries just in case.
3) If none of the DirectTV codes work, you have 3 options.
1) Contact Directv and see if they have additional codes not listed in the manual.
2) Contact your televisions manufacturer and see if they have additional codes to try.
3) Purchase a 3rd party remote that works with both devices..
Jun 03, 2009 | LG 32LB9D TV
Apple remote control
At the bottom of the remote is a small button that can be pressed by a pin or pen. Press it and the battery will pop out. Replace the battery and you will have a working remote
Mar 09, 2008 | Apple MA128GA Remote Control
No Remote
The remote have to work with new batteries. You can check the board where the components are mounted and resoled any that look bad. In your case it could caused by a leaky diodes or a bad solder. All can be replaced at a local electronic or hardware store and they're easy to replace Possible batteries problems: 1 batteries are not making contact properly inside the remote. Test by cleaning connections of the batteries and the remote. 2 battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. 3 batteries are bad and are not actually recharging. test by using other batteries if possible. 4 other, unknown, internal remote problem. buy a new one.
Dec 28, 2005 | RCA RS2044 Shelf System
149 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
