Question about Kodak EASYSHARE M1063 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
My Kodak easy share M1063 digital camera turns on, and the lens comes out. But the camera turns right back off and the lens comes back in. Its fully charged but it wont stay on so I can take pictures. What is wrong?
    President:
  • 2,761 Answers
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
  • Vitally Alcher Aug 21, 2011
    Hold the lens with your hands when powering it on , do it several times until it works, also clean with compressed air and fine brush, Vitally
SOURCE: Lens Error 111,0,0,23 on my Kodak Easy Share c743
have a look at this
http://www.josepino.com/other_projects/index.php?lens_error_kodak.jpc
Posted on May 12, 2008
mads_aye
  • 58 Answers
SOURCE: Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Posted on Nov 29, 2008
MNfisherman
  • 11896 Answers
SOURCE: My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
Posted on May 30, 2009
  • 1632 Answers
SOURCE: Can't reset Date & Time
What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
Posted on Jun 02, 2009
SOURCE: my kodak easy share M1063 turns on then shuts right off how do i
I had the same problem; I blew in the lens as it extended and everything's working now. Seems to be VERY sensitive to dust in the lens/zoom mechanism.
Posted on Jul 23, 2009
I have a kodak easy share MD41. It wont come on
that is the most problem of kodak battery once you leave the battery inside of your camer awithout using for a long time. the battery life become less or easily damage.
Jul 08, 2010 | Kodak EASYSHARE M1063 Digital Camera
Kodak easy share, lens will not open camera will not come on, even when in plugged in to electricity
I have an Easyshare M1063 camera that will not power on. We need to start a list to get this item recalled.
Jan 31, 2010 | Kodak EASYSHARE M1063 Digital Camera
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have a kodak easy share M1063 and i droped it and now the first lens is slightly crooked and won't retract but it doesn't turn on or off either. What can i do?
you cant do anything other taking back to the shop and saying that it is faulty from the first time you use it that it my only advice because the same thing happened to me!
Oct 04, 2009 | Kodak EASYSHARE M1063 Digital Camera
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
My kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
Jun 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Blown sand in camera, blew out as much as i could.
You got to really clean it good. Probably the sand is in the lens extension preventing the lens to oppen. That is the problem.
Vitally
May 14, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
526 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
