Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Beater bar does not turn but belt is not broke
    Problem Solver:
  • 8 Answers
I think there is 2 belts one for clutch ,one for brush
Posted on Jul 28, 2009
Beater bar does not work
Make and model may help you get an answer.
Nov 02, 2017 | Vacuums
The belt broke; i looked at the on line manual but can't see it very well. where is motor pulley to hook belt to
What belt broke . the beater bar turn it over and take the cover off and look at it .
Nov 27, 2015 | Simplicity Vacuums
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
I am not sure of the part name but on the bottom there is a brush/sweeper that should turn and mine no longer turns.
The beater bar is either jammed with string or threads inbetween the housing or the belt inside of it is off or broke.Turn the beater bar upside down, remove the screws and seperate the housing.Please let me knowif this helps or if you need further assistance
Jan 19, 2011 | Kirby G6 Bagged Upright Vacuum
The beater bar will not turn. I have cut all the hair and lint off but it still will not trun.
is the belt broke ? also try taking the beater bar off the vacuum and then checking the end roller bearings. clean and lubricate with some light oil. make sure belt is solid.
Dec 17, 2010 | Vacuums
The beater bar on my Dyson won't turn. The vacuum runs and suctions but the bar won't turn and the belt is not broke. The beater bar did get a carpet fiber caught and wrapped around it which stopped the...
The belt doesn't have to be broken to make the vacuum not work correctly. If the belt is stretched the vacuum won't operate the way it is supposed to. You can get replacement Dyson Belts here:
Dyson Replacement Belts
Dec 06, 2009 | Vacuums
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Charlie
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum cleaner not picking up
Remove the beater bar and check in the suction cavity behind it. That's where they usually plug.
--W/D--
Jul 18, 2009 | Vacuums
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
229 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
