Question about Frigidaire ATF6000ES Front Load Washer
FRI/FWT449GFS Front load washer manuf in 1999
Turn nob and pull out to start cycle. Shows Locked but nothing happens. Have to keep pressure on door right at latch through wash, rinse and spin cycle to get machine to work
  • WeRalrdy1 Nov 19, 2007
    The answer by Coxy was very helpful because I didn't know how to get at the interlock. What I did was trip the interlock a few times and it finally started working again and I didn't have to remove the interlock. However, next time I may have to remove the interlock and replace it. Thanks Coxy
  • Anonymous Mar 12, 2014
    I have a pressure well and pressure tank for water supply. Flow varies. Can I adjust setting on washer to allow more water to enter drum for wash and rinse cycles?
  • 76 Answers
The interlock is going, Ifr you want to repair Unplug machine. open door and remove just the front part of the door seal, theres probably a metal band around it. where the door catch closes you will see two screws, remove these keeping you other hand around the back, behind screws holding the plastic interlock, there will be three wires attached to this or a plug remove these, remembring where they go, and take the interlock to the local shop. they cost no more than 20 pound
Posted on Nov 18, 2007
I need help with my Duet washer
it sounds like an electronic problem with the board.
Nov 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont complete cycle
Sound like the control board is bad
Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer shows Lr sign on the pad.what does that
that is a locked roter sometimes caused by sudsin unit
Aug 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
Control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
Jun 14, 2008 | Frigidaire GLTF2940ES Front Load Washer
Won't turn back on and finish cycle
Press "end of cycle" for over 3 seconds, & wait for 2 minutes to open door. You can then re-start the wash. It is possible you cld hv damaged fhe door switch. For front loaders you do not open the door during a wash, never. Less problems.
Mar 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Duet front load washer control locked--How do I undo??
Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
468 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
