Question about Uniden TRU9480 Cordless Phone
Can't make or receive calls
We've had our phone about 4 months and it has worked fine until now. the other day we lost our dial tone on this phone set only and we were unable to make or receive calls. i've tried everything that the company has suggested so far and it hasn't worked. now the only difference is that there is static and interference on the line.
  • 4 more comments
  • Anonymous Nov 16, 2007
    i have the exact same problem it all happend yesterday when i got home from school my awnser machine was blinking 57 then 96 and both phones dont work, one is cordless the other isnt when i put my ear to the phone i can hear static but not really loud just qwuite buzz static noise. help me some one!!!!
  • Anonymous Nov 17, 2007
    We've had our phone a 24 months and it has worked fine until the last three months. The other day we again lost our dial tone on this phone and we were unable to make or receive calls. This has happened about six times previously. What has worked each time is unplugging the transformer and reinserting it into the outlet above or below it Electrician checked outlets they are all working properly. No idea how many calls we miss when this happens. What is the problem. The transmitting unit, the trransformer or something else?
  • Anonymous Dec 13, 2007
    Can not make or receive calls and there is no dial tone? Have gone through the Owner's Manual and everything seems to be as directed in the manual but still have not dial tone. Also have checked power sources which are o.k. and the handsets are fully charged. Would appreciate your help.
  • ned746 Dec 13, 2007
    Have no dial tone so can not received incoming or make outgoing calls. Have gone through Owner's Manual following steps and checked power sources (which are fine) and both phones are in full charge. Would appreciate your help.
  • stopby232321 Jan 04, 2008
    Had the same problem--everything worked fine for several months, then one day nothing but on the base unit and all the remote units. Used a different phone (non-uniden) to verify that the phone outlet the base was connected to was fine. Tried a variatn on the fix mentioned in the November 17, 2007 post and it worked. Here's what I did:
    1. Unplug the power from the wall outlet.
    2. Reset the outlet (the outlet is of the ground fault receptacle type)
    3. Wait 10 seconds.
    4. Plug the base unit back into the same outlet.
    5. Base unit worked (dial tone and no static) and all the remote units worked as well.
    Resetting the outlet was probably not needed--the answering machine was on and had power, so I don't believe there was any problem with the outlet. Still, I did it just for the heck of it. My guess is just unplugging the power, waiting a few moments and then plugging the unit back is all that's needed.
  • Anonymous Jan 31, 2008
    I haven't taken any steps. On the display it says flash.
    The model number is KX TG5432.
  • 310 Answers
Are you running a wireless router? try unpluging router to test phone.
Posted on Jan 07, 2008
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Dialtone, but no dialing
Uniden offered a replacement, stating that the base phone was probable beyond repair.
Jun 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Jan 08, 2009 | Brother IntelliFAX 4100 Laser Fax
No dial tone. No calls. Can't call out.
Dec 28, 2008 | Uniden Cordless Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Cannot call out or answer a call
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Feb 01, 2008 | Panasonic KX-TG6021 Cordless Phone
GE 28111 Twin Cordless Phone "Line In Use"
I had the same problem. I went to each handset and pushed the talk button. After I got a dial tone, I pushed it again to stop the dial tone. The message went away.
Aug 14, 2007 | GE 28111 Cordless Phone
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Uniden TRU9480 Cordless Phone Logo
150 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
