Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Burning plastic smell
Unexpectedly three of my air purifiers produce very aggresive smell when on. It seems comingfromthe filters. Smells like burning plastic. I cleaned the filters, but smell did not go away.
SOURCE: sharper image quadra silent air purifier has red light flashing
Have you cleaned the bars lately? I believe that red light means that the bars that collect the junk from the air are at capacity and needed to be wiped down.
If you don't know how to do this, pull them out from the top after having turned the machine off. Get a rag or paper town moist, but not dripping and just wipe the black soot off all visible sides of the metal bars. Lay it aside when done over night for it to dry completely, then re-insert them into the machine. Turn on and hopefully that should take care of it!
Posted on Jul 12, 2008
SOURCE: air purifier can't work.
I would go to the store you got it from and see if they know anything about it cause maybe they can give you a refund or even a new one
Posted on Oct 01, 2008
SOURCE: I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Posted on Dec 22, 2009
SOURCE: Have cleaned unit and will not work. The clean
i cleaned the whole unit with alcohol, took it apart gently q-tipped it gently and now its working. i am so happy. i love this unit!! thanks for lindaangelo!!
Posted on Feb 16, 2010
  • 28 Answers
SOURCE: cleaning light stays on
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Posted on Mar 09, 2010
When I turn my brand new air purifier on on it smells like its burning or going to catch on fire is it supposed to?
That unit is a very heavy duty machine that uses ionization to clean air. There is a high voltage power supply that is used to generate ions. The unit can release ozone and that substance has a definite smell to it. If you have ever been near a copy machine or an electric motor that sparks, you would smell ozone. The concern is whether or not it is ozone. Ozone is regulated by the manufacturers to be held at a permissible level because at high concentrations it is an irritant and can cause respiratory issues by itself. The power unit for that air cleaner is on the top near the back and you can run the machine for a while to see if that area gets hot. That would be a bad sign. All the documentation is here: http://electronicaircleaners.com/f50f1032parts.aspx But if you don't trust the unit, take it or send it back.
Feb 20, 2016 | Honeywell (F50F1032) Air Purifier
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
No ozone smell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 19, 2010 | Ecoquest Flair Air Purifier
My Flair smells like it is burning and the plates are making a loud sparking sound
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 01, 2010 | Ecoquest Flair Air Purifier
It is not putting a good smell in my home, It smells like cigarette smoke. I have a classic air purifier, and a newer model with ultraviolet light. They both do not put a good smell, in fact the one in...
Hello, To smell like cigarettes, you would have to be smoking ? I would recommend calling the manufacturer and describing this problem to them. Somethings going on, and I would start there. I hope they can be of help to you.
Good Luck, Shastalaker7
Nov 04, 2009 | Ecoquest Living Air Classic Air Purifier
WET DOG
Hi Teresa,
that is certainly not the smell the machine should produce :)
The smells, other then fresh air, might be 'trapped' in the filter. So washing the filter (top rack of the dishwasher works for the metal mesh filters) might do the trick.
Another trick you can try is to put the purifier on the floor, turn it on high mode (away mode) and put a box over it. Let it run for an hour or two and the smells should be gone.
Make sure you have fairly new plates, to make the machine more effective.
Dutch
Jan 11, 2009 | Ecoquest Flair Air Purifier
Smell in the air
If the smell is not electrical as JEShandyman was asking, but rather from something trapped in the lint filter you could try putting the unit under a box and put it on sanitize. Let it run for 30-60 minutes and see if that cleared up the problem. Washing and drying the filter first is a good idea.
You should never get a head ache from the smell the machine produces. The fresh air the machine produces reacts with the odors and contaminants in the environment and that can potentially create other smells. If that happens you should scale the machine back to a lower setting and take it very slowly and ramp it up day by day. This is something you should have been told by the person who sold you the machine to begin with.
I hope this helps.
Eric
Nov 12, 2008 | Ecoquest Breeze AT Living Air Purifier
Kenmore air cleaner
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
Mar 23, 2008 | Kenmore 85250 Air Purifier
Air Purifier smells like chlorine
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Dec 13, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Need to buy replacement filters
Here is the link; http://www.hamiltonbeach.com/cgi-bin/main/co_disp/displ/pgname/trueair_home/strfnbr/20 Hope this helps :)
Dec 01, 2006 | True Air Plug-Mount Odor Eliminator with...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
255 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
