Question about Nokia 5200 Cellular Phone
Mic isnot working but when i record he works well
When i rocrd it works but when i call nothing happens
The mic on compaq laptop wont work
vista and windows 7 took sound driver by default this work partially download driver for sound from compaq site for full funtion mic dosent work without proper driver.
Feb 04, 2012 | Computers & Internet
Hi there i have an xps 420 computer and my mic isn't working it says its plugged in and recognizes it but no sound come out and i even tried recording and nothing happens. i tried my mic on another...
first you can check your mic is muted..just open control panel and there will get the option of sound properties after u can check there mic is muted or note.otherwise you must reinstall your audio sound card driver because this issue is same as audio driver problem.if u still have the same issue after reinstall your driver you must reinstall your operating system.if still have the same issue?? you must check your mic port of your computer.thank you.
Sep 05, 2011 | Dell XPS 420 PC Desktop
My webcam works fine on other websites but when i try to talk nothing happens. It works fine when i test it but not on websites
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Aug 25, 2010 | Logitech QuickCam Fusion Webcam
My nintendo ds lite microphone isn't working!
suspect the mic has gone faulty if it went all of a sudden.
Jul 04, 2009 | Nintendo DS Lite Console
C773: Audio -Internal Mic low sound, external not working
please check the settings from control panel->sounds and audio devices , there you can see voice-voice playback and voice recording.. , if not yet solved the problems, then you have to catch Service center
rd
siva
Jun 22, 2009 | Compaq Presario 700 470024-192 Notebook
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
No recording?
GarageBand on Windows makes your music move everywhere, and now you're able to utilize GarageBand to get Laptop/PC. With live Applications, it makes it effortless to get more pleasure in creating music like DJ by triggering loops and audio effects in real time plus GarageBand free Application allows you to do things that you can never perform on a true instrument. GarageBand For PC Download GarageBand For Windows Mac
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Nx7010 mic problem
Did you check the sound settings for the mike?
May 08, 2008 | HP Compaq nx7010 Notebook
Hi i have an hp pavilion dv2000 lap top, i am trying to record my acoustic guitar into the comp. This lap has conexant high definition audio sound card inbuilt. However when i try and plug a microphone...
The mic may be muted on the computer. In XP, double click the volume control icon in the bottom right of the screen to get the mixer. If you don't see the microphone input, go to 'options' then 'properties' and place a check in the box to show it. Then make sure it is unmuted and the volume is up.
In Vista, right-click the volume icon and choose recording devices and make sure it is on and volume up.
Apr 23, 2008 | Computers & Internet
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Nokia 5200 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
