Question about Dell Sk-8135 Keyboard
Dell keyboard number lock issue
When the computer is restarted or turned back on, the number lock key has to be pressed...is there a way to set it to stay on at restart?
    Scholar:
  • 56 Answers
There is in fact an option in the bios, hit the DEL key as its booting and once in you should see the option for it, cant remember the wording but its something like Num Lock on Boot or something. If for some reason you are having trouble locating that or its just not there, you can have windows XP do it for you. !!!THIS IS A REGISTRY EDIT!!! Do not change anything but what is specifically posted here or you could foul up your system!
Go to your start menu, select run, type regedit
Navigate to the following in the Registry:
HKEY_USERS.DEFAULTControl PanelKeyboard
Double click on 'InitialKeyboardIndicators' in the right hand pane.
Set the value to 2.
Posted on Jul 12, 2009
How do i reboot a dell optiplex 960 to factory settings if i cannot login?
How to enter BIOS?
1. Turn on or restart your computer.
2. Press "F2" to enter "System Settings" (BIOS) when the DELL icon appears.
Restore the BIOS to default settings.
Press "Caps Lock", "Num Lock" and "Scroll Lock" buttons to light up the corresponding lights on the keyboard. Then, press the following three combination keys:
Alt+E - Clear (Release) the interrupted resources and reallocate resources at next startup. After pressing the combination key, you will hear a sharp beep tone.
Alt+F - Restore BIOS to the default settings. After pressing the combination key, you will hear a sharp beep tone.
Alt+B - Restart the system.
Password clearing method 1: When the password input box appears, type in the password and press "Ctrl" and "Enter" simultaneously.
Password clearing method 2: Remove the PSWD jumper on the MB and start up the system. Set the password to empty in BIOS, shut down the system and reconnect the PSWD jumper.
Hope this method will help you otherwise check Dell Optiplex 960 Manual- https://guideusermanual.com/product-name-optiplex-960-manual&po=344822&lang=English for expert's suggestions.
Dec 24, 2016 | Dell Computers & Internet
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
How to lock a keyboard
  1. Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
  2. Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
  3. Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
  4. Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
  5. Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
Aug 22, 2010 | Dell Vostro 1015 Laptop Computer (Intel...
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    The keyboard is locked
    Dear Sir,
    plz folow this step to unlock keyboard
    1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
    3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
    4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
      For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
    5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
    6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
    Thanks For Your Time,
    Apr 13, 2010 | Dell adamo PC Notebook
    Dell keyboard locked up
    Dear Sir,
    PLzz folow this step to unlock your keyboard
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    I am at work in a hospital. Our IT people are not here at night. I can not get my Dell keyboard to respond. When I touch any key, it makes a soft beeping nose, but nothing happens. I think I accidentally...
    First of all make sure that the Number lock or fuction lock are not on. Press one of these keys and see what happens.
    Secondly if the keyboard is part of a desktop unit, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
    Good luck and please post back if you need anymore assistance.
    Regards.
    Feb 19, 2010 | Dell Spacesaver USB Keyboard J4624 SK-8115...
    Keyboard is not responding it does sometimes then stop again
    Step 1
    Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    I restarted my computer and keyboard not working
    It sounds like you might have accidentally turned on the laptop number lock. I am assuming you are seeing that characters are being typed, but the password is not accepted. If this is the case, try turning off the num lock by pressing the FN key (usually found by on the lower left by the CTRL and/or ALT keys).
    If this doesn't work, trying entering the BIOS when starting the computer (usually by pressing F2 repeatedly when you see the DELL logo). In the BIOS look for an option for the numlock and turn it off.
    Last shot - I have seen a few times where num lock is remembered when an external keyboard is used and then stays enabled on the laptop after it is disconnected. If you used a plugged in keyboard and/or use a docking station, you may want to try plugging in the keyboard again, disable NumLock (above the number pad on the right) and then shut down. Remove the external keyboard and I suspect the laptop won't have this issue.
    Hope this helps,
    Chris
    Mar 23, 2009 | Dell Inspiron 8600 Notebook
    Number lock won't turn on
    When enabled, this allows the user to type numbers by pressing the keys on the number pad, rather than having them act as up, down, left, right, page up, end, and so forth.
    in bios is where you can set number lock to enable at start up
    so restart and enter set up(bios) and change it to lock numbers at start up
    if you need more help just let me know
    electech
    Oct 23, 2008 | Dell Inspiron 6000 Notebook
    Dell Sk-8135 Keyboard Logo
    199 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
