Question about Refrigerators
Heavy frost in freezer, warm refer compartment.
We have a K.A. KTRS22K refrigerator, top freezer. Just recently the stuff in the refrigerator spoiled. There was a large amount of frost in the freezer, and after unloading the refrigerator to let it defrost open to the 75 degree garage I removed the 1 shelf in the freezer and the bottom pan. Ice still in there after 5 hours. Question, suspect bad defrost timer?
I blew out the condenser with the air compressor. The garage ambient could hit 80 but no more. The gaskets on the freezer door are not cracked, but you can hear a small whistle after closing the freezer door.
  • blakpot1 Jul 12, 2009
    Sweet, I do have some skills in this dept. 38 years as a HVAC mechanic. Got the meters etc. Thanks. Ice is gone after 7 hrs open to 75 degree ambient. The fan runs. I'll check the heater for continuity. Is the defrost timer suspect possibly by not entering a defrost mode? The Defrost stat, does it terminate defrost or start the fan after the timer kicked in the compressor?
  • blakpot1 Jul 13, 2009
    Well, the heater is ok in the continuity dept, same with the defrost stat, opened and closed with rise & fall in temp on the evap. outlet. Where is the timer hidden. Around back by the compressor?
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 12, 2009
  • 1 more comment
  • Mike Price
    Mike Price Jul 13, 2009
    Yes the defrost timer is a candidate, if you have a mecanicle timer advance it into defrost cycle, if the defrost cycle begins and you see melted ice on the evaporator it's going to be the timer...some timer are built into the control board though and it's not possible to advace them...so with this your going to have to eliminate everything else before replacing the board if the timer is shot. The defrostcan be tested by checking condinuity when it's in place and before you defrost the evaporator...depending on your refridge make and model it will either show condinuity below 50f or 40f..will normally have temp printed on stat....
  • Mike Price
    Either in the console where the cold control is or take the grill off bottom front..will look up your model..will massage again if i find it.
  • Mike Price
    well you didnt give me the whole model number but i found it i think..if I have it correct its going to be in the console in the refridgerator normally located some where on the roof near the light. Mike
Kenmore elite refrigerator
You have a sealing issue I'm guessing you have an ice dispenser on the door that is letting in warm air. If not your gaskets need to be replaced
Aug 10, 2013 | Refrigerators
Refrigerator and freezer too warm; freezer has heavy frost in back of the compartment
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 09, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Our Amana side by side is not cooling very well in the refrigerator or freezer. Stuff at bottom of freezer is frozen, but stuff at top of freezer is melting. Same with the fridge. Stuff at the bottom is...
It sounds like the unit may be "frosted-up" or the circulating fan has stopped running. (regardless of the frost-free system). I have had to take them apart, (the inside rear wall) and defrost behind there. Push the button on the door switches and see if the fans start to run. If they don't start blowing or make squealing noise then you need a new fan(s). So a service call may be in your future unless you want to dive in with a hair dryer and tools. In any case, enjoy eating everything before it spoils.
Dec 05, 2010 | Amana Refrigerators
Poor cooling in the freezer compartment
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 29, 2010 | Refrigerators
Refrigerator to warm freezer OK
first check the fan...make sure it is running.
next defrost the freezer unplug and open the doors untill all the frost is gone about 24hrs at room temp..
plug it back in and see it it will work better ..if it does you have a defrost problem... let me know
Nov 12, 2008 | Frigidaire Refrigerators
Warm refirig compartment
is there a heavy frost build up in the freezer section?? do you hear the fan running?
May 20, 2008 | Kenmore 77870 Top Freezer Refrigerator
The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Feb 17, 2008 | Frigidaire FRS26ZSG
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
The refrigerator compatrment won't cool but the Freezer works
my bottom freezer frig digital controls have a line going thru instead of a number,the frig is warming up as is the freezer. lost my manual.Please Help
Aug 26, 2006 | Jenn-Air JBL2086HES Bottom Freezer...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
