Question about Lexmark X2600 InkJet Printer
Lexmark 2600 scanning to MAC-no can do
The 2600 won't scan onto a MAC using OSX. Hitting the scan button on the Lexmark launches Mac's Image Capture, but no matter what you choose, the SCAN command tab won't highlight and allow you to choose it. The manual's MAC section has scanning instructions for old MAC OS, but OSX and Image Capture do recognize the printer and model.
Edward, I have this same problem. Were you able to solve it? Anyone, can you help? I have installed the drivers. When I connect the printer to my Mac, it launches ImageCapture and previews the scan fine. But I am unable to get the "scan" button to become active, adn there is no place to save the scan. If I click "save pdf to iphoto" it saves a pdf of the entire screen, rather than just the photo. Appears not to be Mac compatible for scanning purposes. Thank you for your help.
Posted on Jul 15, 2010
  • dianne507 Jul 15, 2010
    Ok--found the answer on another help forum.
    If you have this same problem: click on the photo/document that is previewed in ImageCapture. Drag to the area you want to scan. THEN the "scan" button will become active and you can save your jpg.
    Not exactly intuitive, but thank goodness it works!
  • PupParent Jan 27, 2011
    Fantastic. The answer from dianne507 got my scanner working. Thank you so much.
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
I can get the Lexmark Pinnacle Pro901 to scan a single page using the sheet feeder but it will not scan multiple pages. The first page completes successfully with a a 'Scanning Canceled' message....
Since Mac Lion OS has just been released, your scan issue might need further troubleshooting. Please contact Lexmark Technical Support Center for assistance.
Aug 09, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Scan wont work on mac psc 1410v
First are you trying to scan using the scan button on the all-in-one or from the computer? If you are trying to use the scan buttons, you need to install the HP full-feature software package: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=458978#N193 . (If you need to expand the section marked drivers.) Uninstall the printer and disconnect the data cable before installing this full software.
If you installed the basic drivers that came with the Mac OS, you can scan using Apple Preview and Image Capture software. You can also acquire a scan from the Print & Fax > Printer browser. Open the software from the dock or from the Applications folder. In Apple Preview, choose File > Import from Scanner. In the Image Capture program select the all-in-one from the list of devices.
For the Print and Scan. Open System Preferences from the Apple Menu. Click Print & Fax and select the all-in-one. Click the Scan tab and Open Scanner. Then click Scan.
With the HP software you can launch a scan from the computer or from the scanner (but only if the monitoring program is running). You need to set up the HP Utility for the scan task manager.
This site has the full set of steps: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02456650&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=458978#N2158 .
Sometimes an all-in-one will work for printing but not for scanning due to a damaged cable. Scanning requires bi-directional communication with the printer. Try replacing the data cable. If you use a USB hub or print server, try a direct connection to the computer.
I hope this helps.
May 14, 2011 | HP PSC 1410 All-In-One InkJet Printer
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
I am trying to scan pictures onto my computer using lexmark 2600 series
How to Scan on Imac using the Lexmark 2600:
1. From the Imac Desktop select the Magnifying glass in the upper right corner of the screen.
2. Search for Preview
3. Open Preview App
4. Put item to scan on Lexmark Glass Face down and close the lid.
5. Select File (In Preview from Top tabs on desktop), then Choose 'Import
Image'
6. Lexmark 2600 Series Window opens
7. Change Scan to Folder, Name and Format to your choices
8. Use cursor to highlight area of image to scan in the 2600 Series Window.
9. Hit Scan from the 2600 Series WIndow.
10. Save the file using the File tab in Preview, and choosing Save
Aug 27, 2008 | Office Equipment & Supplies
Can't scan from pixma mp760 to mac book
you can also try image capture (comes with every mac) to scan files.
Aug 07, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cannot operate scanner
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
Nov 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark X2600 InkJet Printer Logo
2,780 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
