Question about Garden
Weed Eater Edger won't start
My Weed Eater Edger PE550 bought in October 2005 died while using it and won't restart. I changed spark plug, fuel filter and air filter. I don't think it is firing and it appears the spark plug wire may be broken at the point it enters the house by the on/off switch. I don't know how to get the casing off to get to the spark plug wire. I removed all the torx head screws but cannot get the casing apart.
How do I change the plug wire?
Keith
Blackberry_U
  • 223 Answers
SOURCE: Weed Eater GTI 15 won't run???
Check the gas lines, one might be bad...
Posted on Jun 01, 2009
panilling9
  • 284 Answers
SOURCE: weed eater starts but dies under high idle
The gas used to be primed right on the ground so the EPA regulations made them put it back in the tank.
so primer side in tank enough to be a dumping point.
Probably will have to remove and check carb. rubber components for pliable and clean all the orifices you see.
if its bad dismantle carb. completely and put in a carb. cleaner solution and let it sit for awhile
Posted on Jun 21, 2009
bbreton
  • 437 Answers
SOURCE: ECHO 2000 WEED EATER I changed the fuel line,
You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
HTH
Good Day.
Posted on Oct 29, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
SOURCE: Weed Eater Problems
The Zama carburetor remains sensitive to ethanol additives in gasoline.Assuming there are no fuel line leaks,you could buy a rebuilding kit online at e replacement.com. Rebuilding instructions often appear om youtube.Its simple.The rebuilding works about 40% of the time.A new carb is around $40 online.
Posted on Jun 12, 2012
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Why weed eater wont stay started
  • #1 - Change Fuel Filter
  • #2 - change or clean Spark Arrestor
  • #3 - Change or clean Spark Plug
  • #4 - Clean carburetor
Order of importance, Start at #1 and work forward.
Look here...
Jul 22, 2014 | Echo Garden
I have a PE550 Weed Eater Edger and have new carb, new fuel lines, new ignition module, new gas filter, new gaskets, and new air filter.... and it still won't start, what should I do now?
Theres a screw for gas and air mixture on it you need to turn it all the way in then turn it 1 and a half times out , its a perfect factory setting the push primer 3x and turn on choke pull 2x then turn off choke should run hope this
Sep 28, 2013 | Health & Beauty
I have a 12 year old Ryobi weed eater/edger....have never had problems until last year...at first, it would run for a while then cut off...I'd have to wait an hour or so until it would crank and run...
This sounds to me like you have a fuel flow problem, check filters and strainers. Old fuel sometimes gels and gums up jets and strainer/filter screens. change the plug, but that is likely not involved with this issue.
Apr 22, 2011 | Garden
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a poulan weed eater edger. It will start and run but when I move the choke it stalls. I want to clean the air filter but I don't know where it is.
I am not familar with all models of all things but you will find the air filter in the close area of the carburator intake. The filter cleans the cumbustion air prior to entering the carb. Good luck...Lee
May 28, 2010 | Poulan Pe550 Gas Edger
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Jun 28, 2009 | Poulan Pe550 Gas Edger
Garden Logo
802 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
