Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
Same problem. Unplugged the machine. Doesn't work.
Same problem. Runs for about 2 minutes then up pops the code. Tried all the standard fixes including replacing the sensor assembly.
Have had the washer for less than 2 years and have been having the same problem. First date of service was told by a tech there is no problem. Within three days same error code came up. Again, tech came out and have been waiting almost two weeks for the part to come in. For those who have had the repart repaired, does this solve the problem?
