Question about Broderbund The Print Shop 22 Deluxe Full Version for PC
I am continually receiving an error message when I try to open Print Shop 22 - either Windows cannot access the specified device, path or file. You may not have the appropriate permission or Could not access the specified target. Access denied. I have installed and run PS22 before without these problems
    Scholar:
  • 113 Answers
Have there been any operating system changes ? like moving from xp to vista ? this would be a simple upgrade if that was the case , has your product id expired ? i'd go to the manufacturers site if none of the above has changed and see if they still support the software ?
Posted on Jul 13, 2009
Windows cannot access specified device path or file
Windows cannot access the specified device path or file. You may not have appropriate permissions.What's annoying about this message is that sometimes it has nothing to do with permissions at all! Here's a couple of possible ways to fix it, depending on your system.
Note: First, restart your computer in Safe Mode (only XP and Vista) and see if you can open the file or programs in question. If so, it's not a "real" permission issue, it's a program or process on your computer that is giving the error.
The best solution that has worked for most people is to simply uninstall Internet Explorer enhanced security configuration.
Method 2 - Turn off anti-virus or firewall If you are having this issue in Windows XP or Windows Vista, then your problem is probably related to an actual permission issue.
Norton Internet 200X, Bitdefender, AVG anti-virus, Trend Micro 200X can all cause this problem. If you have any of these programs installed, make sure to disable them and test it you can run programs, open files, etc.
If so, then you'll have to either use a different program or find something on the Internet about to how to configure your software to not interact badly with Windows.
The same thing can also happen with an overly aggressive firewall. If you are running Comodo firewall or something similar (other than the basic Windows Firewall), then disable that also.
Method 3 - Unblock the file If neither of those two methods worked, the file may be blocked by Windows. Note that this is only for Windows Server 2003 and higher.
When you copy an EXE file from another computer to a Windows Server 2003 box, there is what is called a blocked property set on the file. This is due to the increased security on servers.
Right-click on the file and choose Properties. You'll see a button called Unblock at the bottom.
Method 4 - Real permissions issue Finally, you may actually have a permissions issue. In this case, make sure you are an Administrator or you are part of the Domain Admins group if you are in a domain.
Also, you can try right-clicking on the file and choose Run As. Then type in the Administrator credentials and try to run the file. If you are able to run it, that means you account is not setup properly or is not in the rightuser group.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 09, 2014 | Microsoft Windows 7 Ultimate for PC
File folders from my usb cannot be opened unlike individual files which can be opened. upon opening a message from trend micro office scan appears, as follows: plug in device (usb)...target:...
Try to right click the drive and go to properties. On the drive properties window, click on security tab then change the permissions from there.
Hope this helps.
Jun 27, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Recently all my programs receive an error Error message: Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access the item. Some of my...
Sounds like a virus/malware.
Scan with Malwarebytes in safe mode (F8 on boot up)
I would also switch your system restore off while you virus scan, lots of nasties can hide there.
Its up to you if you turn it back on later.
If you dont have any Antivirus ( but i think you probably will have :) )
Try AVG9 FREE or Microsoft Security Essentials
Aug 20, 2010 | Microsoft Windows XP Home Edition for PC
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Windows cannot access specified device, path, or file... app perm
sounds to be a bug in the system
ensure the program is working, goto system restore and turn it off
turn back on again, this will remove all the old ones, they could have the bug in them,
create a restore point now, then download "combofix.exe"
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
run this
it gives a report when finished, the top section shows deletions, this is the stuff it found
Nov 12, 2009 | Dell OptiPlex GX260 PC Desktop
Windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item
It is simple ...... u got to be an administrator to install any software ..or you should be given Rights to Install any thing in the machine ...
Till then u will recive this msg on the screen
Apr 23, 2009 | Computers & Internet
Nothing is opening on my laptop
hi, you may be using windows XP with NTFS file system.
some body/virus has redused the file permissions in your system. Scan the system with an updated virus scanner.
thanks
Aug 16, 2008 | Toshiba Satellite A135-S2386 Notebook
Try to using Admininstrator user and passwor or the user id and password which have preveleges.
Thanks
Iqbal
Jun 16, 2008 | Acer Aspire 4315 Notebook
Broderbund The Print Shop 22 Deluxe Full Version for PC  Logo
476 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
