Question about Memorex Televison & Video
I need a owners manual for my memorize mvr4040a... my universal doesn't recognize it.. i need to know how to set the time without a remote... thanks
    President:
  • 1,126 Answers
Http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices
This site has owners manuals for most universal remotes.....just find your manufacturer and model number. Hope this helps.
Posted on Jul 12, 2009
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
Lauson code
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 28, 2014 | Universal Remote Control Televison & Video
I receieved a SYLVANIA 6432GG TV with a remote. The remote control doesn't work. The previous owner had programmed a Comcast remote control to use on the TV. I don't know how to reprogram t
GOOGLE THE MODEL NUMBER OF THE SET (IF ORIGINAL REMOTE) WITH "manual" which would get the owner manual to do this.
Each set is different in this process.
Apr 08, 2012 | Sylvania 6432GG 32" TV
I don't have a remote for a LG 32L89D. How can I turn it on without it?? Please help!!!
If no manual power button on front or side of set (unusual) you need to purchase an original remote (not a universal-waste of time and money.
If you do not have an owner/user manual for the set Google the exact model number with "manual" to locate one..
Apr 06, 2012 | Televison & Video
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
Aug 13, 2011 | Televison & Video
How do I get my att&t u-verse remote control to recognize my 51 inch samsung TV?
The remote can't recognize the tv, it doesn't have that capability. If you want to use it to command that tv you must program it accordingly. Basically you must introduce the code that corresponds to the set of commands that your tv uses - if they are present in the remote.
This is the programming procedure:
1 - hold down the TV button on the Uverse remote. As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
2 - Find the 4 digit code for your device in the User guide that was given you when the Uverse was set up, or online at
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
3 - At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. If it turns off then turn it on with the remote and test the other buttons. If they don't work then try a new code.There are a lot of codes for Samsung in there, try them all until you find the one that has the best compatibility - most buttons that can be used.
4 - If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter to memorize it. This generic code will provide just a basic control, if you really need full control then you will need another remote.
Jul 02, 2011 | Televison & Video
Need to tranfer codes to jumbo remote,Think I need owners manual
Don't see an answer to this old question, but I just bought this unit. The box has an address: www.mscustomercare.com. Went there and was able to download the manual without any problems. Codes can be manually downloaded or learned from your older remotes.
Jan 25, 2009 | Televison & Video
CC, SAP PIP
1) Try hard reset = unplug TV for some time,plug-in,try again.
2) Follow guide instructions carefully = one missed step is all it
takes
3) Consult owner operator manual
4) Further help? provide Model # off back of set..................T.
Jan 02, 2008 | RCA Universal Remote Control
Televison & Video Logo
539 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
