Question about Garden
Ryobi cordless chain saw leaks oil. Runs fine. When I remove battery and store on shelf...a few days later I notice a puddle of oil. What to do?
    Scholar:
  • 173 Answers
The problem is, that it doesn't require 'movement or inertia', to draw/or pump the oil.
It syphons through, naturally.
The only solution is, to not store it with oil remaining in the reservoir.
That's it I'm afraid.
There is no way, to stop it from drawing oil through, without stopping it from working correctly.
Happy, (& safe;) chopping.
& plz don't give me the thumbs up, thanks :)
Posted on Aug 01, 2009
I have a Remington Electric Chain Saw, Model # 111174-01. I can't keep oil in the reservoir. it leaks and runs through the seam in the bottom of the housing leaving a puddle wherever it sits.
The Owner's Manual says "IT IS NOWMAL FOR OIL TO SEEP WHEN SAW IS NOT IN USE. EMPTY OIL TANK AFTER EACH USE TO PREVENT SEEPAGE." Istore mine on a cookie sheet.
Sep 17, 2011 | Remington Electric Chain Saw
I just bought a Ryobi 18v cordless chain saw. Filled the oil reservoir, pumped etc and used. Left it overnight and now the contents of the reservoir are all over my garage floor. Instructions said to...
Man, I know what you mean. If I am not going to use my saw, I empty my saw oil back into
the oil bottle using a large funnel to catch it all. Then I can put the saw in a large cardboard box
lined w/layers of newspaper in an upright position til next time. Works great! Get back to me if
you need help sharpening that puppie...............dansky66
Mar 26, 2011 | Ryobi Factory Reconditioned 10-Inch 18...
What oil does a ryobi cs216 electric chainsaw use ?
if you are talking about the bar chain oil (?) --- then all you need is just that ' bar/chain oil ' ,, you can get it from any hardware store that sells chainsaws.
now out here in the middle of nowhere Alaska where I am,, we just use used motor oil from our generators as a bar chain lube and it works just fine, ( not my ideal thing to use , but that is what the boss says to use and after 3 years here and using it -- I have not had any issues with our 4 saws that get over 3000 hours of use every year ).
I say -- use only good,clean and new bar chain oil.
c...
Jan 18, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
Bought a Ryobi cs214 at a pawn shop. There is no oil in the holder for smooth running of the machine. Would like to know what kind of oil does the Ryobi CS214 takes.
Just fill the tank with regular bar/chain oil available at home centers, hardware stores, and saw dealers. Don't use old used motor oil or similar. Hope this helps!
Dec 21, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Just received recondition Ryobi 18 volt chain saw. Motor runs backwards.
electrical motor was wired in reverse, If you you attempt repair assuming product was purchased from store ,your sure not to get a fund or in-store credit.
Dec 07, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
My chain saw (14 inch gas powered) would not
Modern chainsaws have the ability to run without turning the chain via the chain-brake. To set the brake the uppermost handle is pushed forward (toward the chain) and a firm snap should be heard and felt. To release the brake you pull the same handle back (towards the engine) and get the same "snap".
Concerning oil leakage: Bar/chain lube collects on the inside of the clutch cover and the sawdust mixes with it as you saw. A surprising amount of oil gets absorbed in the sawdust and later seeps back out when the saw is at rest. If the level of oil in the tank noticably drops after sitting overnight you may have a leak...otherwise it's normal.
As for a running chain that wont cut, it is common for chains to be installed backward and the unit still function perfectly (it just won't cut wood). See the proper chain orientation here. In this photo the chain travel is from left to right.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Bar oil leaking
My guess is the tube has come loose inside.
Apr 19, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Oil leak
jdawg's right; the manual states that you must empty the oil after using it. Even after you do so, expect a few more drops to leak out over the next day or so - that's what mine does. I use some of the oil-absorbing pads that you can pick up in marine stores or auto parts stores, just let it sit on one of those for a while till the resevoir is completely empty.
Apr 13, 2009 | Remington 16" Electric Chain Saw
Garden Logo
1,239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
