Question about Kenmore 61042 Top Freezer Refrigerator
Ice builds up on evaporator coils. After chipping off the ice, refrigerator is cold again. This lasts only a few weeks as ice builds up. Eventually, the freezer is cold but the refrigerator is very warmer. Suspecting the evapporator fan needs replacing. Any suggestion is much appreciated.
  • gsmoua Jul 13, 2009
    No this is not a frost free model. Any other thoughts?
    model is kenmore 253. freezer on top - refrigerator on bottom.
    Problem Solver:
  • 13 Answers
Assuming this was originally a frost-free model, either the defrost cycle timer died or the defrost heating element died. If it's the timer, you might be able to manually start and end a defrost cycle every few days. If it's the heating element, you may be stuck with what you're doing or an expensive repair or buying a new refridgerator.
Posted on Jul 12, 2009
Samsung bi-metal defrost thermostat
If the coil is good, it could be that the defrost timer is not allowing enough of a defrost cycle resulting in ice buildup after various cycles. The ice is never being complete melted and it just keeps building up.
Mar 13, 2017 | Samsung Refrigerators
Refrigerator wont stop running
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
Jun 15, 2012 | Refrigerators
Refrigerator running too much
May 30, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Why is my side by side not getting cold enough? No airflow to fridge and freezer not as cold as usual.
The first thing I would check is that the evaporator fan is working! The second thing I would check is the defrost circuit (defrost heater, defrost thermostat and defrost timer) functioning. If you have ice build up on and around the evaporator then you have a defrost circuit problem. You can check the defrost heater with an ohm meter (continuity means good).
If you manually defrost the unit (a hair dryer will speed things up) you can have the time to order the parts while you have use of the unit, since it will work a few days up to a few weeks before the ice builds up again.
Jul 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
It stopped working. All food defrosted. Not cold inside although feels cold when pulled open. No ice.
check the evapor coil and fan how much frost build up.if no ice build up.
check condensor fans and coil how dirty. if it ok
check compressor .relay
good luck
Jan 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Ice building up in fridge
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Jul 12, 2009 | Refrigerators
Freezer side will not keep ice cream, popsicles or orange juice frozen. it will make ice in ice cube trays-the ice maker makes very few ice cubes.
check
Jul 06, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer is freezing
common problem is part number 67003375 adaptive defrost control. also reccomend replacing part number 67003964 at same time. control located in refrige behind left upper panel. def therm clipds on evaporator behind panel in freezer.
Feb 06, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Dec 19, 2007 | Maytag MSD2456G Side by Side Refrigerator
Kenmore 61042 Top Freezer Refrigerator Logo
134 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
