Question about Sta Rite 1 Hp Above Ground Pump Ne641
Pump will not turn o until it reaches 33psi. How can I adjust it so it turns on @ 45psi?
    President:
  • 1,723 Answers
You have to adjust the pressure switch to sense 45 PSI. Turn the adjustment CW just a bit and try it. Then adjust as needed.
Posted on Sep 01, 2009
Hard start cold, fine rest of day
I would be checking to see why there is power to the pump with the ignition off as this is a source to flat battery overnight.. May be a relay is still activated by a power source other than the ignition.
Jan 25, 2014 | 2000 Chevrolet Blazer
I'm trying to change the belts for my 92 tercel but some how cant find the tension pulley. Can anyone please help me. I need to change both belts.
It appears that your car is equipped with multiple v-belts, rather than a serpentine belt so there most likely aren't tensioner pullies. Here is some general info that may help.
Alternator To adjust the tension of the alternator drive belt on older models, loosen the pivot and mounting bolts on the alternator. Using a wooden hammer handle, or a broomstick as a prying device, move the alternator one way or the other until the proper tension is achieved. Do not use a screwdriver or any other metal device such as a pry bar, as a lever. Newer models use a tension adjusting bolt. Loosen the pivot bolt and the locking bolt, then turn the tension adjusting bolt until proper tension is achieved. Tighten the bolts securely, run the engine about minute, stop the engine then recheck the belt tension. Air Conditioning Compressor A/C compressor (always use caution when working near the A/C compressor to avoid damaging the refrigerant lines) belt tension can be adjusted by turning the tension adjusting bolt which is located on the compressor tensioner bracket. Turn the bolt clockwise to tighten the belt and counterclockwise to loosen it. Air Pump To adjust the tension of the air pump drive belt, loosen the adjusting lever bolt and the pivot bolt. Move the pump in or out until the desired tension is reached. NOTE: The tension should be checked between the air pump and the crankshaft pulley on cars without air conditioning. On cars with A/C the tension should be checked between the compressor and the crankshaft pulley. Power Steering Pump Tension on the power steering belt is adjusted by means of an idler pulley (some models may use just a lower adjusting bracket setup, similar to the alternator adjustment service procedure). Loosen the lock bolt and turn the adjusting bolt on the idler pulley until the desired tension is felt, then tighten the lock bolt.
Feb 12, 2011 | 1992 Toyota Tercel
Belt routing
V-BELT ADJUSTMENT CAUTION
On models equipped with an electric cooling fan, disconnect the negative battery cable or fan motor wiring harness connector before replacing or adjusting drive belts. The fan may come on, under certain circumstances, even though the ignition is OFF. Alternator Drive Belt
  1. Position a ruler perpendicular to the drive belt at its longest run. Test the tightness of the belt by pressing it firmly with your thumb. The deflection should not exceed 1?4 in. (6mm).
  2. If the deflection exceeds 1?4 in. (6mm), loosen the alternator mounting and adjusting arm bolts.
  3. On 1968-72 V8 and 6 cylinder models, use a prytool to move the alternator toward or away from the engine until the proper tension is reached. NOTE: Apply tension to the front of the alternator only. Positioning the prytool against the rear end housing will damage the alternator.
  4. On 1973 and later V8 models, place a 1 in. (25.4mm) open-end or equivalent wrench on the adjusting arm bolt and pull on the wrench until the proper tension is achieved.
  5. Holding the alternator in place, tighten the adjusting arm bolt. Inspect the belt tension. When the belt is properly tensioned, tighten the alternator mounting bolt. Fig. 1: Alternator belt adjustment 86651054.gif
Power Steering Drive Belt ALL 6-CYLINDER AND 1971-72 V8 MODELS
  1. Holding a ruler perpendicular to the drive belt at its longest run, test the tightness of the belt by pressing it firmly with your thumb. The deflection should not exceed 1?4 in. (6mm).
  2. To adjust the belt tension, loosen the adjusting and mounting bolts on the front face of the steering pump cover plate (hub side).
  3. Using a prytool on the pump hub, move the power steering pump toward or away from the engine until the proper tension is reached. Do not pry against the reservoir as it is relatively soft and easily deformed.
  4. Hold the pump in place, tighten the adjusting arm bolt and then inspect the belt tension. When the belt is properly tensioned tighten the mounting bolts.
1973 AND LATER V8 MODELS
  1. Position a ruler perpendicular to the drive belt at its longest run. Test the tightness of the belt by pressing it firmly with your thumb. The deflection should be about 1?4 in. (6mm).
  2. To adjust the belt tension, loosen the three bolts in the three elongated adjusting slots at the power steering pump attaching bracket.
  3. Turn the steering pump drive belt adjusting nut as required until the proper deflection is obtained. Turning the adjusting nut clockwise will increase tension and decrease deflection; counterclockwise will decrease tension and increase deflection.
  4. Without disturbing the pump, tighten the three attaching bolts. Fig. 2: Power steering belt adjustment (slider type) 86651055.gif
Air Conditioning Compressor Drive Belt
  2. If the engine is equipped with an idler pulley, loosen the idler pulley adjusting boot, insert a prytool between the pulley and the engine (or in the idler pulley adjusting slot), and adjust the tension accordingly. If the engine is not equipped with an idler pulley, the alternator must be moved to adjust, as outlined under Alternator Drive Belt.
  3. When the proper tension is reached, tighten the idler pulley adjusting bolt (if so equipped) or the alternator adjusting and mounting bolts. Fig. 3: Air conditioning belt adjustment 86651056.gif
Thermactor® Air Pump Drive Belt
  2. To adjust the belt tension, loosen the adjusting arm bolt slightly. If necessary, also loosen the mounting belt slightly.
  3. Using a prytool, pry against the pump rear cover to move the pump toward or away from the engine as necessary. WARNING
    Do not pry against the pump housing itself, as damage to the housing may result.
  4. Holding the pump in place, tighten the adjusting arm bolt and recheck the tension. When the belt is properly tensioned, tighten the mounting bolt. Fig. 4: Air pump adjustment points 86651057.gif
Nov 12, 2010 | 1988 Mercury Grand Marquis
ICE-O-MATIC ICEU220HA2 bridge too thick. Is the time delay relay the "finnish" relay that adjusts bridge thickness? If so, I'm not getting any change in thickness with time adjustment.If the time delay...
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU220 with R-404A should cut in at 45psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Apr 06, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 | Watches
I can't turn the alarms off on my Casio GW-330ca
Setting CASIO G-Shock Watch 1) Home City
3) Adjusting hands
4) Alarm set/on/off 5) Snooze 6) Hourly Chime A --- B ( ) Button reference C __ D
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
5) Snooze (SNZ) Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To stop any alarm, press any button. To cancel next snooze, Press C and go to either the timekeeping screen or the snooze alarm screen.
6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
May 09, 2009 | Casio G-Shock G2600 watch
I have the wrong day of the week, when I set the date.
The day of the week will be right after setting the year, month, and date. Adjust with step 2) from timekeeping mode (where time, date, and day can be toggled with button D).
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A --- B
C __ D
Press C until timekeeping mode is reached (high beep).
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 27, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I cant set the digital time in casio illuminator
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Watch
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Aug 08, 2008 | Casio G-Shock G510D-1AV Wrist Watch
Sta Rite 1 Hp Above Ground Pump  Ne641 Logo
107 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
