Question about RTO TIF Instruments Low Side 134a Auto Glycerine Refrigerant Gauge
Where do you put the refrigerant - RTO TIF Instruments Low Side 134a Auto Glycerine Refrigerant Gauge
    Problem Solver:
  • 5 Answers
Refrigerant in an automotive system should always go on the low side of the a/c system to prevent damage or injury. If attempting to refill on the high side, the extremely high pressures generated by the a/c compressor can actually exceed what is in the refrigerant can, causing the can to overpressurize and even explode. Plug the adapter hose (sometimes included with the can, sometimes not) into the low side port, identifiable by its blue cap. If no cap is available, it is always the smaller of the two ports. The high and low side ports are always different sizes, so if the one you're trying doesn't work, you probably have the wrong one. As far as where the port is located in your engine compartment, that is different with every car. Usually it is relatively easy to see and access. The simplest way to find it is by tracing the two metal/rubber hoses coming from the front of the engine compartment (from the "condenser", a part which looks very similar to a radiator, but is usually located directly in front of the radiator) back to the firewall (or rear of the engine compartment). One of these two lines will end up leading to your a/c compressor, a part which looks similar to your alternator or power steering pump (in that is has a pulley in the front and is belt driven). This is your high pressure line - ignore it. Trace the other hose back to the rear of the engine compartment, and somewhere along it -before it disappears in the interior of your car - you'll find the low side port located on that hose
Posted on Jul 19, 2009
Fridge is not cooling and the freezer stopped freezing. Can i just buy some freon or a new refrigerator
Lori,
You cannot just go out and buy Freon to put into a refrigerator like you can for a car. They take a different kind of Freon and you have to have special equipment to put it in. I would suggest calling a repairman and discuss your problem with them to see if you should have them come out or just replace the unit. One of the things you should also consider is the age of your current refrigerator. If it is more than 10 years old, you might just want to use the money that you would put into a repair call into purchasing a new refrigerator. Hope this helps!
Mar 25, 2015 | Refrigerators
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Bad smell in freezer
Put a vinegar in plate and put the plate in the freezer. Leave it for few hour. Works better if refrigerator switched off .
I always do that with my refrigerator & my micro-oven (careful not to turn ON while vinegar inside - i don't what will happen).
Dec 10, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
I have already put refrigerant in my 1994 mercury sable but it still blows out hot air.
what kind of refrigerant you put on your system? you are contaminating the system and which may compromise the efficency to take away the heat from the cabine to the atmospheric air.so make sure yoy put the right refrigerant and thereis no leak in the system.
Jun 01, 2011 | 1994 Mercury Sable
My ice maker is not working I put in a new one it will not fill up, or empty if i put water in it, also my icecream stys soft it will not freeze,I clean the compresser and the coils behine the fan but it...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2010 | Maytag MTB2176 Top Freezer Refrigerator
I put in 35 quarts of applesauce last night and this morning everything in door and top shelves were defrosted. Is it not working?
If you put 35 quarts of warm applesauce in there you probably defrosted it iwth that....I as long as it seems to be running and you can feel cold air I would give it more time...
heatman101
Sep 03, 2010 | Freezers
Putting refrigerator lock on freezer door
he may have punctured a freon line you will know for sure if it stops cooling.
Jan 31, 2009 | Magic Chef CTF2125 Top Freezer...
Microwave ontop of refrigerator
Your microwave can be put on top of the fridge without causing any problems however I dont recommend plugging into the same outlet as the fridge as most newer fridges are completely computerized and are very sensative to power surges
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
RTO TIF Instruments  Low Side 134a Auto Glycerine Refrigerant Gauge Logo
138 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
