Question about Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas
Service AGS Heater lights and as soon as the fan turns on high it shuts off. it runs for about a 20 second cycle. Heater reads Service AGS.
  • sonjabihary Jul 12, 2009
    Just to clarify the heater is natural gas and not propane. Replaced gas valve and cleaned flame sensor. Fan is running before, during and after. Isn't showing any other codes except service AGS. Gas turns on, starts to heat, when fan kicks on high the flame shuts off.
    New Friend:
I have had this problem more than once over the years. The first time I found cleaning the igniter rod by lightly sanding it with an abrasive cloth or sandpaper corrected the situation. The second time was one that I really struggled with, as it would sometimes work after moving wires around. I finally found the solution had nothing to do with the heater itself, but was due to a loose ground wire in my timer box. Cleaning and reconnecting the three ground wires was all it took. I can't tell you how long it took me to finally find this solution.
Posted on Aug 04, 2013
  • 3,230 Answers
It seems that there is a relay problem or the fan condenser.
so, do check them first.
Good Luck!!
Thanks
Posted on Jul 12, 2009
  • Mukesh Kumar Jul 13, 2009
    It sounds as if the ignitor has failed. It is about an 80 dollar (or so) part for your heater. Before the gas valve opens, you should see an orange colored glow in the burner area.
Explain the code error r9 and what is the solution
I don't have a definite solution however r9 is a heater problem it could be a short curuit between the heater and ground make sure the ground wire has not become loose or corroded
Jul 19, 2015 | Washing Machines
I have a Master Temp 250 pool heater that shows an AGS error on the back of the board. The heater runs for about 20 seconds then shuts off, any ideas?
AGS = Auto Gas Shutoff...
What is happening is the heater is monitoring (or sorta, by reasons difficult to explain here) Water Flow and Water Temperature. In this case, the AGS is triggered by a low water flow, or high Incoming Water Temp.
High internal water temp = triggered AGS.
If you have and can confirm, PROPER water flow, water temp coming into heater is Lower than 104°, then it is possible you have a faulty AGS.
But in most cases, it's only doing its job. Locate the reason for the fault, or why the AGS Switch turned the heater off.
Jun 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
I have a 75000 btu garage heater ,20 years old, The Fan stoped turning on and I replaced both the switches that turns the fan on by the heat exchanger and the shut off switch.It still will not turn the...
The high limit switch is shutting down too soon (too low of a temperature) or the fan on switch is not turning on at a high enough temperature...are they in backwards??? Even though the switches work they are not turning on and off at the right temps... so they may be out of calibration....
heatman101
Feb 10, 2011 | Heating & Cooling
My Laars LX pool heater would shut off soon after it fires up
This error is Automatic Gas Shutdown. Here is what you can do:
  1. Check for fluctuating pump pressure (air in strainer, pressure guage bounce)
  2. Check all wiring connections
  3. Replace ignitor/flame sensor assembly
Depending on your expertise, it could also be the gas valve or ignition control (aka the IID).
Since the burners do fire briefly, I would suspect the flame sense rod first. Attached is a link to the owners manual in PDF.
Lo Nox heaters can be a little tough so follow the directions exactly.
Jul 24, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
AGS code
AGS switch wiring may be bad. Jumper the switch at the molex connector on the board using a paper clip, with the plug still plugged on. Restore power.
Dec 04, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas Logo
530 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
