Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
How to work router
When I installing router with the disc, I would get to part 11 and It would not let router connect to internet. I have an cabel internet
  • 57 Answers
Router can't connect directly to internet by itself, you need to have a modem. Your router need to connect to your modem and the modem will connect to WAN.
Posted on Nov 16, 2007
How to install my router for wireless internet on my laptop.
1. Purchase a wireless router that fits your needs and price range.
2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
7. Click on "Properties."
8. Select the "Wireless Networks" tab.
9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
10. Click on "Configure" when you see your network's SSID in the "Available Networks."
11. Enter your network's SSID and WEP key.
12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Thanks.
Have great day.
Oct 01, 2010 | Computers & Internet
I dont have the easy install disc
You dont need disc to configure...To access Belkin's web based setup page type 192.168.2.1 on the address bar of the browser.
By default there is no password set for the router and you just simply click submit button to log on to router setup page
Click on Internet WAN and select the connection type you want.
Wireless name (SSID) is the name of your wireless network. The most recommended wireless channel is 6. You can use wireless channel 1 and 11 to and scan for the network
Jun 04, 2010 | Belkin (F5D7230-4) Router (VVLZ253558)
Step 11 and 12...
Hii , Some time what happens we are not able to install the router using the setup disk .So in that case we have another option to install the router...
For Cable Internet connections :--
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686
For DSL 9Phoneline) Internet connections:-
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
If you find this information helpful . Pease rate information
May 31, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How do i change the channel on my router
put in the disc again and run the installation and when it asked me to run the installation it asked me what channel I wanted it on but the default was 11 so I kept it there, just try to set it up again
Jan 25, 2009 | Belkin (F5D7230-4) Router (587009)
Siemens speedstream 2624
you have to configer your router are you using dsl or cabel inter net
cabel you dont need to set in log on but dsl you do
secound configer your router wireless i think you are are useing dsl speed stream bell use
Aug 15, 2008 | Siemens SpeedStream 2624 Router...
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Unplugged Power and Now Unable to get a connection with router
Make sure that the Ethernet Cabel is plugged into the computer and attached to the router. make sure another ethernet cabel is attached from port 1 of the router to the Modem. Hope this works.
Feb 19, 2008 | Dell Wireless 2350 Router
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Can this be used with a MAC?
Any router will work, TCP/IP is a network standard, definately double check the cables. Your DSL modem is usually 192.168.254.254. and the router is usually 192.168.1.1. Check your documentation for the default IP. Once you know it type it in to the broswer in your Mac. Before doing so connect with an ethernet cable, purchase a new one if necessary. Connect from the <--> labeled port on the mac, or ethernet port. These wires are not like phone lines, they have 8 wires instead of 4/6. The router usually has ports on the back labeled 1, 2, 3, 4, and WAN. the 1-4 ports are LAN and that is also labeled on there. Plug the mac into port 1 and any other computers in after you get internet. once the physical connection is recognized. Go to your browser in the mac and proceed. if you get a web based router configuration page your router is working, then make the WAN connection to the ethernet port on the back of the dsl mode. Be sure your cables are good. Also go to your control panel and make sure your internet is enabled in your network section.
Jan 06, 2008 | Siemens SpeedStream 2624 Router...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
