SOURCE: HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
SOURCE: hdtv stb issues hdmi - dvi for Acer AL2416W
Hi
I have a Acer AL2416W and a PS3 and cannot get them to connect using hdmi - dvi
how did you get yours to work
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini. The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz). The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process:
1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application)
2) Connect the Mac to the TV
3) Connect to LogMeIn from another computer (preferrably one where you can see the TV)
4) Go to Applications / System Preferences / Display
5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
If you have the owner's manual, there should be a procedure to reset the TV back to factory default mode. Try that. If that doesn't work, I'm afraid you may have a bad microprocessor(one of the computers inside the TV)
