posted by evangeline on Nov 16, 2007
Motherboard won't boot up
Comment by evangeline, posted on Nov 16, 2007
The model number was P4i45gv and the memory was the problem. Removed and reseated and it worked.
Best Solution
Your model number does not match any in Asrock's Product list - What CPU is installed?
Some of the things that will cause a non boot motherboard are:
1. All of the power cables are not attached. Does your motherboard have a square, 4 pin connector? Is there a cable from the power supply plugged in it?
One of your cards are not fully seated. Check your video card -
Hope this helps!
Hope this helps!
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP (D9896-69007) Motherboard
HP (KZM-6120) Motherboard
HP PavilionCongo Motherboard Skt462 Via KM13A AMD 2 Dimm Motherboards
HP (5185-6477) Motherboard
Apple (661-2795) for iMac Motherboard
ASUS 865G (MBAS-P4P800VM) Motherboard
ASUS K8N4-E Deluxe Motherboard
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
