Question about Dell 0Y3740 Keyboard
How do i get the number lock light to stay on when computer starts up?
    Problem Solver:
  • 15 Answers
Right click on my computer->properties>advanced tab>environment variables>under system variables, click new>type variable:NUMLOCK, value:ON
restart pc
Posted on Jul 12, 2009
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
3 Lights on display panel Dell D505
YOU HAVE A FAULTY BIOS.I HAD THE SAME PROBLEM WITH MY DELL INSPIRON 5150.REFLASHING THE BIOS SOLVED THE PROBLEM.GOOD LUCK.
Sep 11, 2009 | Dell Latitude D600 Notebook
2003 ram 5.7 electrical problem
run a status check on the pcm. sometimes those probs are in the computer. the loghts will come on when the remote is activated, and the door locks should lock automatically when you start to drive. if that doesn'tr happen, suspect a computer glitch.
Jul 20, 2009 | 2004 Dodge Ram 1500
Power light comes on but nothing appears on monitor
Mostly your heatsink damaged your motherboaard. check caps lock LED and Number Lock LED are working after switching on. If not ur motherboard or processor get damaged and u had mentioned what happened. Ur heatsink shorts some circuit in  your motherboard
Apr 06, 2009 | Compaq Presario 5000 PC Desktop
I restarted my computer and keyboard not working
It sounds like you might have accidentally turned on the laptop number lock. I am assuming you are seeing that characters are being typed, but the password is not accepted. If this is the case, try turning off the num lock by pressing the FN key (usually found by on the lower left by the CTRL and/or ALT keys).
If this doesn't work, trying entering the BIOS when starting the computer (usually by pressing F2 repeatedly when you see the DELL logo). In the BIOS look for an option for the numlock and turn it off.
Last shot - I have seen a few times where num lock is remembered when an external keyboard is used and then stays enabled on the laptop after it is disconnected. If you used a plugged in keyboard and/or use a docking station, you may want to try plugging in the keyboard again, disable NumLock (above the number pad on the right) and then shut down. Remove the external keyboard and I suspect the laptop won't have this issue.
Hope this helps,
Chris
Mar 23, 2009 | Dell Inspiron 8600 Notebook
Weird electrical glitches
It sounds like the sonata computer might be corrupted. Do you use mp3, or ipod to play music through your stereo and or do you play burned music? It's my belief that the computer can become corrupted from maleware code. Also do you know if there was any command start installed or removed? Command starters are notorious for causing computer glitches and malfunctions in the locking mechanisms.
Jan 27, 2009 | Hyundai Motor 2004 Sonata
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Dell 0Y3740 Keyboard Logo
314 people viewed this question
Alun Cox
