Question about Craftsman Rear Mount Tiller
Shifter handle is lock in reverse. will not move to forward. or engage tines in eitherer directions.it stays reverse travel. shifted fine then went to move it then i couldn't move it. but in reverse
  • 394 Answers
The gears are crossed up in the transmission.
You may get lucky if you try with the engine OFF,turning the trans pulley in the direction opposite of which the motor turns. This might unlock the internal gears.
Sorry for your problem. I know it is time to get the ground ready.
Posted on Mar 13, 2010
2003 dodge neon goes forward no problems but no reverse
If we assume it's an automatic....and the shifter locks in position for each selection...etc....
1. Your transmission fluid is too low or too dirty to engage reverse.
2. Your reverse bands are worn out or damaged from shifting to or from reverse while moving forward?
Mine had reverse totally burned out but drove ahead fine...for a while.
Apr 29, 2015 | Dodge 2003 Neon SXT
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
Ford taurus will not engage in reverse or forward
Well, yes the solenoids would cause the transaxle to not function right.
Are you sure the trans is not engaging, or are the brakes locked on ?
You say it shifts fine, you mean you can move the shift lever ?
Jun 29, 2012 | 1996 Ford Taurus
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Husqvarna crt900 tiller wont pull or engage tines
make sure all the linkage pins are in place
Apr 04, 2012 | Honda Garden
Changed starter and now transmission won't engage in reverse. What happened?
is the level of fluid ok ? im afraid your transmission went bad not because of the starter change but it just happen at that time
Jan 10, 2012 | 2003 Kia Sedona
20001 vw jetta tdi automatic transmission problem
Ok , so you got home , parked it and when you started it up the next day and shifted it into reverse... backed out... and went to shift into drive , it stayed in reverse ?
Have you checked to see that the cable has not disjoined itself from the shifter to the trans.?
Are you able to engage Park?
Nov 10, 2011 | 2001 Volkswagen Jetta TDI
Transmission question
hi i will try help, well yes it will have adverse results on his gear box if he is putting it in drive and then reverse before the vehicle stops going forward, ile explain, when you engage the gear and drive forward, the centrifugal force is sent to the torque converter This engages reverse gear within the transmission, giving the ability for the vehicle to drive backwards. In order for the driver to select reverse, they must come to a complete stop push the shift lock button in (or pull the shift lever forward in the case of a column shifter) and select reverse. Not coming to a complete stop can cause severe damage to the transmission. Many modern automatic transmissions have a safety mechanism in place, which does to some extent prevent (but does not completely avoid) inadvertently putting the car in reverse when the vehicle is moving forwards. This mechanism usually consists of a solenoid-controlled physical barrier on either side of the Reverse position, which is electronically engaged by a switch on the . Therefore, the brake pedal needs to be depressed in order to allow the selection of reverse. Some electronic transmissions prevent or delay engagement of reverse gear altogether while the car is moving. Some shifters with a shift button allow the driver to freely move the shifter from R to N or D, or simply moving the shifter to N or D without actually depressing the button. However, the driver cannot put back the shifter to R without depressing the shift button to prevent accidental shifting, especially at high speeds, which could damage the transmission.so hope that answers your question and end the feud lol, please vote thanks
Mar 03, 2010 | 2002 Volkswagen Jetta TDI
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Craftsman Rear Mount Tiller Logo
253 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
