Question about IBM ThinkPad R32 2658 Notebook
IBM THINKPAD R32 Tryin buttons to boot won't work?
Hi, I try evry button to boot from CD ain't working? LIKE F2 BUTTON F8 Can someone tell me how to boot from cd IBMP THINKPAD R32 INTEL PENTIUM 4 Thank you
  • IBM Master
  • 32,281 Answers
Normally when as you bootup press F12 and you get a list of devices that you can select to boot up.
If the doesn't work go into the BIOS setup and go to the boot order configuration and set the CD as the first boot device. Later you can change it back if you wish.
Posted on Jul 13, 2009
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
My computer will not boot windows xp os
Do you mean it won't pick the disc? If so, try F10 it should also give you a boot menu if you don't see press any key to boot from cd... The other option is boot into BIOS and change your boot order. CD-ROM/DVD should be the 1st option.8_28_2012_7_14_07_am.jpg
Aug 28, 2012 | IBM ThinkPad X41 Notebook
Laptop turns on, goes to first screen which reads IBM TRHINKPAD. THEN FLASHES OFF TO NEXT SCREEN WHICH READS THE WINDOWS XP LOGO then it goes black and doesnt come back on
Your installation of Windows is most probably corrupted. Try pressing and holding the F8 button on your keyboard when the 'IBM THINKPAD" screen disappears. That should bring you to a Windows menu where you can select various modes. Select Safe Mode and press enter. If it boots, then you know that something's wrong with Windows and not the notebook itself. What have you installed prior to this problem? Maybe you should try uninstalling it while in safe mode, and then try starting up Windows normally again.
If your windows doesn't start anyway, you should get some live OS (OS that can boot from CD) like Ubuntu or Puppy Linux, so you can save the data from C: partition (burn it or copy it elsewhere) and then reinstall your copy of Windows XP.
Sep 01, 2011 | IBM ThinkPad R32 2658 Notebook
I have an IBM ThinkPad R32 2658 N4U laptop. Problem: When I press the Power button, it does not boot. I followed one advice which was to take battery and unplug it then pres power button 10 times, then...
It could be the battery or the power converter in the computer.
But after a closer reading it sounds more like a chipset error.
Does it work if the battery is completely removed and you boot on just the power cable?
On this link you can find the latest drivers for the chipset:
https://thinkpads.com/support/Thinkpad-Drivers/download.lenovo.com/lenovo/content/ddfm/R32.html
I can also see that it is an older model. You don't mention what version of windows you are running, but if you are running XP or earlier that says something about the age of the thing.
It could be that it is just simply worn out.
Luckily almost all the Thinkpad models are build to last, so you could take it to a shop and have them run a diagnostics on it and replace what ever parts that might be failing.
Just be adviced that the price for the diagnostics would most likely exceed the value of the laptop.
Personally I would get a tech savvy person to get the harddrive out (myself in my case), plug it to a second device with cables as an external drive (can be bought in most wellstocked computer hardware stores) and then do a backup of any essential data.
Mar 11, 2017 | IBM Computers & Internet
Ibm thinkpad t41 does not boot up...just black screen...fan works
hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
Jun 21, 2009 | IBM ThinkPad T40 2373 Notebook
Access IBM Button does nothing-- need it to start my comp up
The Access IBM button is F11. This lets you boot the recovery partition. It is possible the previous owner removed the recovery partition to regain the hard disk space it uses.
If the recovery partition is gone, you can order the recovery disks from IBM/Lenovo.
Also, make sure you have the BIOS boot sequence in the correct order.. the primary boot device should be the cd-rom for installing the Vista disk. It is usually F8 on startup to load the BIOS.
Make sure the Vista disk is in the drive when you startup the install.
Here's a link to all the Thinkpad R50e drivers you'll need to get it fully working in Vista:
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html
If you have just formatted, have you let the Vista disk finish the installation? Just a thought..
Good Luck!
Chris (ziraffa)
Dec 29, 2008 | IBM ThinkPad R50e Notebook
Ibm thinkpad tablet won't boot, says insert set up cd rom which i no longer have
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. thanks and have a nice day J-
Dec 10, 2008 | IBM ThinkPad X60 Tablet PC
Unable to restore OS in IBM-R51
after the booting oftions boot to c: hard drive.. press F8..
Mar 24, 2008 | IBM ThinkPad R51 Notebook
IBM R32 ultrabay is not recognized
Did you leave the battery in the R32 for long enough for it to charge up? (Like overnight?) Another thought is that if you bought the battery used, it may not be any good.
Ron-
Feb 23, 2008 | IBM ThinkPad R32 2658 Notebook
DVD
I don't mean to disagree with my associate, but DVD players for R series (or T, A, etc) can be found for less than 20.00 US (Ebay is a good example)
For that matter, we've got at least a dozen at our shop which we sell for 25.00
Installation is very simple as well, just pop the old drive out, put the new drive in.
Good luck
Oct 30, 2007 | IBM ThinkPad R31 2657 Notebook
IBM ThinkPad R32 2658 Notebook Logo
682 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
