Question about Irons
The iron has plenty of water in the reseviour but will not steam. I have press the steam button and steam comes out but it will not steam otherwise
    Genius:
  • 1,114 Answers
Your iron may be due for a cleaning. After awhile the ports inside the iron become clogged with mineral deposits.
Try using a mix of 1/2 white vinegar and 1/2 water. place the mix in the reservoir and allow the iron to heat up for steam until the reservoir is empty. Then do a second round with plain distilled water. Clean the the iron plate of residue after it cools.
If the vinegar mix does not work (and you can do the mix a few times) try using a product such as "Lime Away" or "CLR" to dissolve the deposits. Hope this helps.
Posted on Jul 12, 2009
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
Water keeps coming out after pressing steam button
hi i have just looked this information up and apparently that using 100% distilled water can cause your iron to spit and leak, to solve this problem you should press the steam button and keep pressing it until there is no water left in the iron, then try it again, if it still does this, repeat a few times and then the iron should be fine
hope this helps
Feb 28, 2011 | Rowenta DG5030 Iron
MY iron is less than 1 year old. It has been stored for about 3 months. Now when I tried to steam a garment with it, it does not steam unless I hold the steam button down. Otherwise nothing comes through...
Sounds like there was water in the line when it was stored, which caused deposits to bild up in the line and not work without pressure. Hence having to press the button to get steam out.
Try loading it full with really hot water and a small amount of bleach. Steam all of the water out of it into the air. Clean out the resevoir with fresh water after it has cooled and try again.
Please remember to rate this solution.
Feb 19, 2009 | Rowenta Professional DX8900 Iron
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Tefal Steam Generator Model 2911
NO THERMOSTART LIGHT,BUT THE WARNING LIGHT COMES ON
Jan 28, 2008 | Tefal Ultraglide 1549 Iron
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
265 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
