Question about E-Machines Computers & Internet
Have T3624 need drivers for nic card
Have T3624 need drivers for onboard nic card
  • 72 Answers
Try going to eMachines driver support page and see if you can download the drivers for your system.
ALSO TRY:
Here are the drivers for emachines t3624 ethernet: http://downloadfinder.intel.com/scri...nm=PL2KXPM.EXE
Posted on Jul 12, 2009
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
On a Gateway GT5028 - appears the ethernet card was damaged by power surge. We installed a new 10/100 NIC card but Gateway reports it has a problem. Any ideas? Do I need to disable the onboard NIC card...
No you do not need to disable the onboard Network Interface Card. I would suggest to first start by inserting the new NIC card in a dif. Spot.
If you do not have any other spots to insert it, i would double check to make sure you have the correct driver for the correct operating system that you are running, If you know the model # of your nic card i could gladly get you the correct driver. Let me know if this helps. Thanks
Jun 20, 2010 | Gateway GT5028 PC Desktop
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
Emachines T3624 Ethernet controler
well, if you have a built-in NIC card, usually you should have a CD that has the driver for you ethernet controller.
or you might want to visit the link below to download your driver
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3624
I think the one you need is that Intel 845GV Chipset Driver
Mar 25, 2009 | E-Machines eMachines Desktop PC
Sound lost on DFI Lanparty 875
do you have another PCI slot you can remove audio card and try another slot.
If your audio still does'nt work you may need a new audio card
Jan 27, 2009 | DFI LanParty PRO875 Motherboard
Emachine T3624 NIC Problem
Shut the computer off at the beginning of the bootup process look for the function key or keyboard button to get into the bios setup. Press that button and look in the settings to disable the onboard network adaptor.
Nov 27, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Onboard NIC Not connected
remove the nic card from drivers, reboot and check that it is not there,log off put card back in and reboot it should then be regonized
Dec 12, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
266 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
