Question about Garmin nuvi 260W GPS Receiver
Garmin nuvi 260 stuck on acquiring satellites. No matter where I am, it no longer is able to acquire the satellites. Unit is only about one year old. I updated the software and firmware from the Garmin website but problem persists. Any ideas?
SOURCE: nuvi 260
Sounds like you did an incomplete firmware update. Go here:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp and do it again. It should fix it.
Posted on Feb 01, 2008
  • 12 Answers
SOURCE: won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Posted on Dec 09, 2007
  • 35 Answers
SOURCE: Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Posted on Jan 21, 2008
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
  • 23 Answers
SOURCE: Garmin 755T Issue - Firmware Update and acquiring satellite
Hi Bob,
You need to do a complete reset by turning it on and at the same time press the bottom right hand corner of the screen this will reset it to factory condition. having done that when you switch it on again leave some where where it has a clear view of the sky and leave it for about 1/2 an hour. This should sort it out for you. Best of luck.
Posted on Aug 05, 2009
The touch screenon my Garmin Nuvi 600/650 won't work. What can i do?
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jan 21, 2010 | Garmin Nuvi 660 GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
Problem with Garmin Nuvi 260w
No because the date recorded in the unit would have been set via satellite and cannot be changed.
Jan 08, 2010 | Garmin nuvi 260W GPS Receiver
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Nuvi 260
Feb 01, 2008 | Garmin nuvi 350 GPS Receiver
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
1,418 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
