Can ping the copier, is the driver properly loaded, current drivers from sharp web site, network cable good or USB cable? is it a network copier can others print?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
SOURCE: Sharp AR - M161 Copier Driver for Vista
There is a vista driver available for that model as long as you are talking about the M161 not 161. Do you have the optional print kit installed or only parallel interface. If you only have the parallel connection it requires the GDI driver which can be downloaded from Sharpusa.com under support then type your model and select OS and driver type GDI
Hope this helps,
TankMurdock
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
SOURCE: how can i reset the sharp ar-5518 sistem
how we can for the first time set sharp 5518 copy machine
