Question about Macromedia Computers & Internet
Can't run a CD-ROM. Getting error 1005 on .x32 files. The CD won't even read. Do I need to download some drivers?
  • 2,567 Answers
1. Make sure the CD-ROM is clean & does not have scratches.
2. Try cleaning the lens of your CD-ROM drive using a lens cleaning kit.
3. Try reading the CD-ROM on another CD-ROM drive.
Posted on Jul 13, 2009
Need Driver for Dell Laptop (Latitude D600) CD drive(LG CRN 8245B)
It should be availble for free download from either the Dell website or the LG website. Just follow links for support and downloads.
Oct 07, 2010 | LG CRN 8245B (CRN-8245B) Internal 24x...
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
I'm install my new set of recovery disk and i have the same error message 1005 or 100a
These are often critical Windows errors caused by a corrupt registry entry. To prevent further corruption to other hardware and applications on your PC, this problem should be fixed immediately. Risks that can result from not repairing your computer include system crashes, blue screens, and hardware failure. this also can also happen when The volume does not contain a recognized file system. Please make sure that all required file system drivers are loaded . ( solution: Check and repair the file system by running CHKDSK. To run CHKDSK click Start click Run type CMD and then click OK. At the command prompt type CHKDSK /F and then press ENTER.
Nov 11, 2009 | Computers & Internet
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
Oct 22, 2009 | Dell Inspiron 1420 Laptop
Error Message 'F:\ setup.exe is not a valid win32 application'
This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Mar 18, 2009 | Computers & Internet
Dvd/cd stoped workingdevice manger reads code10
Try downloading the file "CDGONE" from the link below and run it. Accept all warnings and this should restore your DVD Drive.
http://www.geekstogo.com/forum/CDgone-file8.html
Mar 17, 2009 | Gateway ML6732 Notebook
Hp pavillion dv1000 cd rom drive
memphisrains -
Sounds as though you may need to reinstall the driver for the laptop's cdrom drive. The easiest way I've found to do this is to download it directly from the manufacturer's web site; In your case, look here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-31831-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Download the file to your desktop (file name is sp30367.exe), and run the installation to reinstall & update the DVD/CD-ROM drivers.
Hope this helps!
-thinstatic
Jun 10, 2008 | HP Pavilion dv1000 Notebook
Cannot download hp laserjet 1005 printer
its old but inshallah will work
this link
http://rapidshare.com/files/203517466/lj1005prnsys-en.rar.html
Jan 18, 2008 | HP LaserJet 1005w Printer
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
71 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
