Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Need to replace red clips that hold rolling brush on 7901 Proheat
On the bottom of the machine, near the belt access area,
is a red retainer plate that holds the black brush arm and
brush in place. Using a Phillips head screwdriver remove the
screw that holds the red retainer plate in place. p/n 5559113
Posted on Jul 17, 2009
How do I replace the elevator lever arm on my bissell 7901-6 steam cleaner
i have a bissell 7901 and i recently replaced the brush belt. now my problem is the brush while is working the brush is not making contact with the carpet. how can i adjust the brush?
Nov 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Replace belt on Bissell 7901 Proheat
On the underside of the unit, you will see a red cover about 1 inch square held on by a phillips screw on one end of the brush roller unit...remove it & you will see the toothed rubber agitator brush belt.
Sep 05, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
the water head are pluged use a tooth brush and some hot hot water and brush it on the tips until they are unpluged
May 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can't figure how to reassemble brush so it won't
there is a clip (sort of "U" shaped) that goes on the side this should take care of your problem.
Apr 16, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Info on how to operate a Bissell Turbo Brush Model 7901-P.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
345erw
Apr 09, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Trying to find a manual to replace power bush belt
heatman101
dsfgsf
Mar 15, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Product instructions
You can change the belts from the bottom, remove the brush roll, then you can reach thru slot to change the pump belt, then the cogged belt. Wasn't sure which darwing you wanted, if it is electrical, let me know.
Dec 27, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Smelled like rubber burning
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and put the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Dec 14, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
211 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
