Question about Samsung LN-R268W 26 in. HD-Ready LCD Television
Upper left part of screen turns blue after about 30 minutes
Sounds like we have the same problem, perhaps manifesting itself in different ways. The problem I have does not move around, but is focused in the top left corner of the screen along the left edge. I believe it has gotten slightly larger in the past few months. It only happens after the tv has been on for a while, and it seemed like it would take longer to happen during the winter, which made me think it was related to heat.
Did you ever take this to the shop? What did they tell you?
  • 304 Answers
You have two possible causes. First the Main bd is going bad and second but most probably the Panel is bad and needs to be replaced.
Posted on Jul 16, 2009
When I turn the machine on I hear the machine on see a the screen light up for approx. 1/2 minute then the machine shuts down all on its own.
It could be one of several issues.
1st: Have you tried plugging into a different outlet on a different circuit breaker?
2nd: Have you tried a different power cord?
3rd. Has there been any power surge/storm before the issue manifested itself?
4th: Does the fuser feel warm at all?
If all the above have been done and you're confident those have been answered properly, then we go to the next possible cause:
I suspect there might have been some sort of damage to the ECU (Electronic Control Unit) board. Not a cheap fix!
Nov 05, 2013 | HP LaserJet M1522nf Multifunction Printer...
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Dec 31, 2010 | Garmin nuvi 255W GPS Receiver
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Screen became blue with a red lock in th upper left hand cover. I manually turned off the tv and can not turn it on.
we need a model and make first please as all makes are different and have different ways to unlock the TV set!!
techman
Sep 02, 2009 | Televison & Video
Compaq 5002US PC won't boot (not even BIOS); no sights or sounds
if the processor was fried, it would not boot at all. i take it that you cannot get into bios? perhaps bios is currupt.
Mar 21, 2009 | Compaq Presario 5000US (D70008-261) PC...
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
I have a blue screen after power up
A power supply problem has likely manifested itself here. A service call is required...accordianman
Mar 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Samsung LN-R268W 26 in. HD-Ready LCD Television Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
