Question about Refrigerators
LEAKS WATER AT TIMES - Refrigerators
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
Look have a 98 contuer running all water out no leaks all hoses working fine .Not running hot but when i go frim a to b all water and cooliant are gone.what is the problem.
If there are no leaks, the engine is probably burning the coolant out the exhaust pipe. Most times its a leaking head gasket.
Jul 16, 2014 | Cars & Trucks
Only have hot water when heat is on
A stuck divert-er valve yes replace head, and know this will not cause leaks leaks,leaks are caused by o seals worn and getting old ..and olives on connections replace the above as needed some times a quick tighten with rench will do it leaks that is
Sep 28, 2013 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Iron leaks. have cleaned it several times. still leaks. iron has not been dropped or damaged.
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Aug 07, 2009 | Black & Decker Prestige X805 Iron
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Replaced water pump for the 5th time and it leaks from the hole u
No , it's not normal to leak.
Either , water pump is bad ( 5 times ? )
or instalation was bad or more likely , leak is not the water pump at all
May 09, 2009 | Ford SVT Cars & Trucks
Leaks from top
Yes it goes to the pan.. you can ues a hair dryer but do not leave it unattended.Or your drain line is clogged to the pan .
Dec 07, 2008 | Home
Humidifier leaks water when turned on
Humidifier water pad comes w/ a mark in one end, that mark should be on top. Also check your feed tube they tend to crack some times. if if still leaks water change the water pad
Nov 14, 2008 | Aprilaire 550 Humidifier
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
