Question about Disney D7000PD Portable DVD Player
The laser head doesn't seem to be moving and won't
The laser head doesn't seem to be moving back and forth and won't read the DVD. The DVD player will however play CD's. Any ideas? Thanks
    Problem Solver:
  • 13 Answers
Be sure you try it with a DVD you know has played in this machine before. It might be you have a player that doesn't work with all DVD formats. This seems likely because you can play CDs. Otherwise it's probably a software problem, and since this is a DVD player not a computer I don't know how to help.
Posted on Jul 12, 2009
My sylvania portable DVD player won't read discs the display says No Disc after the spin. What do I do?
I had same problem with a sylvania portable DVD: no disc. After cleaning the laser didn't work, I took the unit apart, and found that there is a small gear that moves the laser back and forth across the disc.. The gear could easily be misaligned with a rough bump along the drive.. All I did was realign the gear to the center where the disc was. Inside, there was even a small lever to pull back on to do this.. I also noticed a small Ribbon cable connecting the laser to the main board. Again, seemed nimble. I detached the ribbon, cleaned the connectors with alcohol and reattached. Happy to say, it works perfectly now. :). Good luck.
Oct 10, 2011 | Sylvania SDVD7027BL Portable DVD Player
The dvd player side doesn't want to read all discs. Some it just flashes the loading and makes a clicking sounds, sometimes it loads up and freezes on dvds, it does this when i try to put in a cleaning...
The clicking is made by the laser head as it moves across the surface of the disk repeteadly trying to pick up the data signal and failing.
If it has used to work then it's clearly a dirt problem. If a cleaning disk has failed to work then the dust has gone all the way to the reading sensor. To clean it you will need top completely dismantle the unit access the optical mechanism, take off the cover and access the reading head - there blow with the can between the lens and the sensor then with a q-tip wipe the surface of the lens.
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
DVD player tries to read DVD then ejects them
try to open the dvd and clean the laser lens and try moving the laser lens part back and forth and try palying the dvd again
Mar 16, 2011 | Televison & Video
I have a sony BDP-S300 Blu-Ray Disc Player and it takes forever to load movies and at times shuts down the process and reboots can you please help
Try cleaning the laser lens with a Q-Tip and Rubbing Alcohol. You'll probably have to take the case off and then there's probably a cover over the Disk Player you need to take off to expose the laser lens. Here's a link explaining how to clean a laser lens:
http://www.ehow.com/how_6764537_use-alcohol-laser-lens-cleaner.html
If it still doesn't work then check to see if you can move the laser assembly back and forth on the metal rails. If it seems very difficult to move then you can put white lithium grease on the metal rails and on the plastic gears that move it back and forth.
Feb 06, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Why does my dvd player say "cannot read disc"
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence the rejection but the best is for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
Dec 24, 2010 | Sony DVP-NS575P DVD Player
Dvd player not playing all formats
Could be dust on laser or track for the laser guide, as it moves back and forth, may also need lubrication....
Apr 06, 2010 | Onkyo DV-SP800 DVD Player
Dvd player won't read dvds. The player mechanically operates ok in that the disk tray goes in and out. And, the read head moves back and forth when trying to read the disk. I can't see a red light from the...
There can be various reasons.1 is the region code correct?
There a selection of dvd`s which you can`t play,this is in the front of your manual.
Unfinalised discs won`t play etc
Oct 19, 2009 | Televison & Video
Laser won't read?
yes.its the problem of laser .it is called CCD lens that is the problem.it needs cleaning if dust is collected on the lens or replacement if the ccd is weak.so its just clicking and nor reading the discks.
Oct 11, 2008 | Sanyo DVW-7200 DVD/VCR
Toshiba SD-P1400
the lens is bad and need to b changed
Nov 19, 2006 | Toshiba SD-P1400 Portable DVD Player
Disney D7000PD Portable DVD Player Logo
171 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
